Grade A 100% Pure
Casket's Avatar
Tail light mystery putty?
Hi guys.
I did a couple searches and didn’t come up with anything, so here’s my dumb question.
I’m replacing the tail light lenses on my 1988 cab today, and ..well, it’s starting to turn into a comprehensive tail light restoration project. But enough about that, my question is does anyone know what the grey putty that is used to seal the rear access plate on the tail light housings is? Is this stuff some sort of commonly available automotive sealing putty? If I have the opportunity to use the factory solution I’d just as soon do that rather than get creative.
Thanks in advance!
Gary
‘88 911 Carrera Cabriolet
‘87 924S
Cabriolet Racing And Performance C.R.A.P. Gruppe #20
Old 11-02-2008, 03:25 PM
Retired Member
Brian 162's Avatar
It almost looks like the putty you would use holding single glass panes on a wood frame.
I just used black silicone for the rear acess of my taillights. I wasn't looking for concours correct. I just wanted it to seal.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 11-02-2008, 05:33 PM
sleepy911's Avatar
glass shop
most call it dum-dum puddy
Old 11-02-2008, 06:24 PM
Grade A 100% Pure
Casket's Avatar
Something like this??
http://www.woolies-trim.co.uk/pc-1480-121-dum-dum-putty.aspx
‘87 924S
Old 11-02-2008, 07:17 PM
plumbers putty would probably work.
Old 11-02-2008, 07:32 PM
Turboo934's Avatar
3M body putty, can be purchased at a auto body supply store.
Old 11-02-2008, 07:37 PM
joefrantz's Avatar
If its gray, it may be the same stuff that's used to seal the front fenders to the body.
The name escapes me, but it's expensive and only comes in 25 ft rolls.
If you're not tied to the color, the best stuff to use is 3M Strip caulk. It costs about $15.00 for a a box that will last forever.
It's black, permanently soft & sticky, and is packaged in 1/4 inch strips, about 8 inches long. There are many strips per box, and the box is about 4x9, and about 3/4" thick.
You can get it at most auto body supply stores and probably the better parts stores. It's what I'm using for the same job.
Good luck
Joe
Joe Frantz
73 911 T
Old 11-02-2008, 07:50 PM
Grade A 100% Pure
Casket's Avatar
Thanks guys.
Gary
‘87 924S
Old 11-02-2008, 08:33 PM
Cool Is this the stuff?
This link seems to have the right characteristics as described in your post. It is widely available in hardware stores as a conduit thru-wall sealer and can easily be kneaded to any thickness. It sticks well, remains pliable and best of all it is waterproof.
http://cgi.ebay.com/Gardner-Bender-DS110-LB-Pug-Duct-Seal-DS-110_W0QQitemZ360097715208QQcategoryZ26213QQcmdZVie wItem
Old 11-02-2008, 09:15 PM
Check with Wurth.
I do not know exactly the name of the product but they have it and probably they supply it to Porsche.
Old 11-02-2008, 09:39 PM
AtomicDog's Avatar
Known as wire dope officially. Ask any electrician and they will say, "Oh, you mean monkey s#!t." Seriously. Used to seal cable entries into junction boxes, etc. Electrical supply store - $10 = lifetime supply.
Chris
1986 Carrera Coupe
1987 Dodge W250
2000 Volvo V70
2007 Land Rover LR3
Old 11-03-2008, 04:09 AM
djpateman's Avatar
Proform Dum-Dum?
http://www.proformproducts.com/en/products/detail/?id=85
We have been using it for about 30 years, and it appears to have a considerable life.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-03-2008, 07:48 AM
