Backfiring on Decel
This is my track only 85' Carrera.
I want to know if I should worry about my car backfiring. It happens every time I let up on gas at high speed, around 100mph +. It's always one very loud pop. Your input would be greatly appreciated. Thanks, rgd
85' 911 Coupe: Rebuild complete. |
I'm not an expert but I believe whats happening is this: during full throttle the DME injection runs on the rich side of things as it guesstimates the air flow etc, then when the throttle is snapped shut the DME shuts off injector flow, so now you are getting air flow with no fuel, the air hits the hot exhaust with some fuel vapor build up (from the full throttle) in there and its very hot so it pops due to ignition.
1997 Boxster SOLD 1999 R1100S SOLD 1988 Carrera 3.2 |
From what you are saying it doesn't sound like anything to worry about.
Thanks for your input!
19 years and 17k posts...
I had some backfiring on deceleration and I put a can of SeaFoam in the gas tank and after about 100 miles of driving, no more backfires... worked for me.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
this happened to me on the track....
very likely the idle control switch is not staying "off" this is bear to adjust but straight forward |
Exhaust Leak?
Monkey Butt Forespin
My '84 does it with the muffler bypass. Mine's set to run rich anyway (+6% fuel), and with the muffpass it's very noticeable. I've replaced all of the gaskets at the heat exchangers in the past year, and I'm running coppers on the cat & muffler flanges.
I only have very light popping & only occasionally with Ben's muffler.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
There are two main causes for backfire. The first is an exhaust leak. The second is unburned fuel off throttle.
The unburnt fuel should be taken care of in an '85 because the ECU should kill fuel into the cyl off throttle. Unless you keep your foot partially on the throttle or you have a leaky injector, this shouldn't be the problem.
Senior Member
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
wannabee wannabee
Had a similar loud pop before adding 911chips.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
RETIRED
Ditto on the exhaust leak.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
abides.
Ditto on the chip... mine would shoot flames sometimes on decel after I installed a cat bypass and open muffler. I bought a chip from Steve Wong in conjunction with an upgrade to headers, and haven't had so much as a pop since.
Graham 1984 Carrera Targa |
(stock exchangers -w- test pipe and Fabspeed muffler)
'84 911, some sort of red color '05 Subaru WRX wagon |
