Timing Settings ??? A Little Histroy also !!
Hi there,
Ok first of all this car has been a mystry to me when it comes to the engine !! I imported the car In june this year from Arizona to here in Ireland, I have totaly stripped it down inside & out, It was sold to me as a 1975 2.7 Targa, but there was a Carrera badge on the engine lid but he said it was just put there for show. So then i went looking for the engine number but as it has new casings & theres no number, A guy i was in contact with from LA took a look at some photos i had took of the engine and said it was a 3.0 engine, he said it was because of the flywheel ?? Next thing is that it has points, he said this a Carrera engine and it was never released in the USA and it must be from Europe !! I have one number off the fuel Dist:0-438-100-031 (off a 3.0 engine i found) Lads take a look at the engine pictures and let me know what you think: http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/10.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/7.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/9.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/number1.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/3.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/4.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/5.jpg http://i33.photobucket.com/albums/d83/paulmoore1979/WESTWERK/number2.jpg This weekend i need to get the timing sorted out as it seems to be hanging up around 2000rpm's, I think it might be out now as i have installed Pertronxs & the MSD6al Anybody know what i should set the timing to ??:confused: |
Hmm, the 9 bolt flywheel started w/ the '78 SC and was used through the last 3.2 in '89, for '77 and earlier 6 bolts were used
but points were used only through '77 it looks as though the fan is 245mm, which means any year except '78 & '79 which used 226mm best thing is to get the engine # from the vertical face to the right & below the fan, to the left of the oil pressure transmitter. |
There is no engine number there now, the case has been replaced....
| All times are GMT -8. The time now is 04:57 PM. |
