E-Grind cam specifications
I just got back from machine shop to get my specifications for my cams.I had e cams put in for a 2.7 rebuild with mahle RS 90 mm p&c's webers,ssi's and sport exhaust.The specifications are as follows.These were reground from my CIS cams
-Intake duration 219 at .05 valve lift .420
-Exhaust duration 212 at .05 valve lift ..396
I can't find these specifications on any chart.Does anyone know if these are indeed e cams or in fact something milder.
Brent Lineker
1975 911S
weber conversion.
Old 10-29-2008, 06:07 PM
Hilbilly Deluxe
emcon5's Avatar
According to John the Camgrinder's chart, that doesn't match any stock cam.
http://www.drcamshafts.com/911profilesprint.htm
The E should be 230º @.050"with .405"lift on the intake and 222º @.050"with .393"lift on the exhaust.
Tom
82 911SC Coupe
GTI Cup #43
Old 10-29-2008, 10:13 PM
That is the same chart I was looking at too.The machinest told me that the factory specs are the ones he gave me,but I can't find where to look for factory specs.
Brent Lineker
1975 911S
weber conversion.
Old 10-30-2008, 06:09 AM
moneymanager's Avatar
Dumb question, bit off topic. I understand lift and duration, but was does the "at .050" spec tell me? Thanks
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-30-2008, 08:04 AM
Hilbilly Deluxe
emcon5's Avatar
It is just the duration starting and stopping as the cam passes at .050" of lift. It is a simple way to make apples-apples comparisons between cams,as some manufacturers list seat duration, or don't mention what they are talking about. For example, Elgin http://www.elgincams.com/c-por2.html "Our duration figures are the end of the clearance ramp"
Tom
82 911SC Coupe
GTI Cup #43
Old 10-30-2008, 08:11 AM
Thanks Tom, very helpful.
jhtaylor
santa barbara
Old 10-30-2008, 08:36 AM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
They gave me timing specs of- intake opens@29 btdc closes @39abdc
-exhaust opens@39 bbdc closes@19 atdc
Brent Lineker
1975 911S
weber conversion.
Old 10-30-2008, 04:49 PM
ok
those 1970/71 valve timing numbers are incorrect says Allan Caldwell.
the 1969 and the 1970/71 E cam are same so says everyone. The yellow was circled by Stoddard.
sorry for my confusion
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-30-2008, 05:42 PM
