Bitz 'like" EFI O2 sensor ques.
Just installed used EFI system and was arranging and separating sensor wires and needed to disconnect (via connector) the O2 sensor to clean up the area. After reconnecting, I tried to re-calibrate the LC-1. I couldn't... error message essentially said it was dead.
I didn't disconnect the battery to do that - how likely is it that I killed it?
thanks,
Old 06-05-2017, 02:55 PM
Did you depin the connector or simply unplug and plug the sensor back in?
Sounds like you may need to call Innovate's tech support line...
Old 06-05-2017, 03:29 PM
Hi Jayson,
.... just unplugged and reconnected. However, I've moved on and purchased your AEM 4110 controller/gauge unit (I know you mentioned the 30-0300, but this was a good price for the 4110). I couldn't find the "gauge pod" on the AEM site that you'd mentioned. Is that something you could point me to?
Are you still with AEM?... I thought you used to have that in your signature.
thanks,
Old 06-05-2017, 09:17 PM
