Warren Hall Student
Heater duct backdate fabrication project
Here was a fun project for the day.
I converted an early left side heater duct to use on a Carrera motor with it's larger distributor. The pictures are pretty self explanatory. Cut duct, Trace manila folder paper. Cut manila folder. Check fit. Transfer manila folder cut out onto metal and trace. Cut metal. Shape and then weld. Throw on some semi-gloss black. ![]() ![]() ![]() ![]() ![]()
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Dude, you're getting to be pretty good at fab!
s/b in tech area, tho.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Warren Hall Student
Dooh!!
Thanks Bill. I just PM'd Wayne asking him to move it for me. I'm still finding uses for that scrap rocker panel you gave me. It was fun little 3 hour project. Of course Joe George would have done it in 1 hour.
What is your address? I will send you mine asap! ![]() Nice work. Wish I had your skills.
82 911SC Coupe Chiffon / Chocolate 9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD) |
nice work Bobby!
what welder, heat and wire/wire speed did you use?
Tru6 Restoration & Design |
I would rather be driving
Great work Bobby.
I did the same this weekend to clear a twin-plug dizzy. 3.2SS continues - Part III - the assembly
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
