OK so i have been stripping my car for blasting and resto. and today removed the oil tank . Now the tank is all Ali and correct right down to the location of the pipes and float sensor . But it loOKs nothing like the photos i have seen of ones for sale on ebay or pelican forums !!! is it an impostor or is there a change in tanks along the way ?? because this is one nice piece of workman ship
"Funding my obsession one nut at a time" |
Crusty Conservative
Pretty sure that all of the factory original fender mounted tanks were made of copper plated steel, not Aluminum. Even in 1972, oddball year for sure. perhaps you have an aftermarket tank there??
How about a picture>>??
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
heres some photos
Max Sluiter
Wow, nice oil tank!
Who made it? Nice fabrication skill
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
know idea ... there is no markings on it.
Fake...but looks very nice, someone knew what they were doing. I wonder if it's any bigger?
Jay '08 E350 Wagon '74 914 gone '72 T gone |
Looks a decent amount smaller than the original tanks I have - at least compared to ADVTracing's hand. You might think about filling it with water to find out how much it holds.
Marv Evans '69 911E |
so if it's a fake why go to so much trouble making it??? surely it would have cost more to make than buy a new porsche one . it's hard to show in the photos but this is one hell of a piece of engineering
"Fake" is probably not the best word to use. "Hand-made" might be telling. It doesn't look like a one-off but I don't follow the porsche aftermarket. It's entirely likely it's superior to the factory part in every way. Lighter and effectively corrosion-proof for starters. I wouldn't scrap the part unless you are doing a concours restoration or you've found a design flaw.
1989 Carrera 3.2L in 993 bodywork |
Some modified the stock tanks to over come some perceived or real oiling issues under racing conditions.
This may have been someone's approach to such a solution. Or, it the stock tank sprang a leak and someone was skilled enough to fab there own instead of paying to price of a rare one year only used tank of questionable condition.
weigh it, if its aluminium it should be considerably lighter than the original steel one.
mine is out so i'll weigh it later today and post. pretty cool and unique. looks like custom fabrication. was your car a racer? any other upgrades?
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
Crusty Conservative
Thanks for the pictures. that's a nice piece of craftsmanship.
You are in New Zealand, home of a lot of hand built racing cars & cycles over a lot of years. Probably the remoteness of the place makes it more likely to hand craft a solution there. I like it...
Work of art. Are you letting it go?
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s |
wasn't the 911r tank similar in design and construction? i don't think it is an actual 911r tank but i seem to remember a picture of one and it had the square corners like that one. pretty cool.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
Crusty Conservative
Similar construction, but made to go in the front smugglers box area, one's I have seen.
What?!?!
.I then "donated" my old one to TRE for good Porsche karma. ![]() Here's my old one. ![]() Here's where the leaks were. Local radiator shop tried to seal it but no joy.
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
weight on my bathroom scale: 8 pounds.
fwiw, the tanks are copper plated steel. copper doesn't rust, copper plated steel does when the plating is damaged by road debris.
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" Last edited by robmog; 11-02-2008 at 07:45 AM.. |
Gary H 1978 911 SC
That tank would cost $1500 to have made and then it might not function or fit well after you spent your money. A work of art.
AutoBahned
but if it is fabbed out rel. thick Al. it may weigh even more than the sheet steel or Cu ones.. |
I concour...not factory, but looks like it was made by someone who really knew what he was doing.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
