front vibration 1984 911 targa
Had the brakes adjusted several months ago, and after driving 20 miles or so, there is a "grinding/vibrating" noise coming (probably) from the front wheels. The sound continues if car is taken out of gear. If I "touch" the brake pedal, or slightly turn the steering wheel, the sound stops. what's causing this?
Old 11-05-2008, 02:09 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Bearings, They are a regularly maintained item like oil changes.
Very easy to do.
Search on Adjusting Front Wheel Bearings
'85 Carrera Targa
PCA/POC
Old 11-05-2008, 04:58 PM
Again, I don't know how to "find" (use) the search feature on this website, Can you tell me how?
Thanks!
Old 11-05-2008, 05:55 PM
old man neri's Avatar
Brakes adjusted? What's that?
Old 11-05-2008, 08:29 PM
I had the same symptom where the front right will howl at 40 to 50 miles per hour. I turn the wheel or tap on my brakes and it will stop. Mostly happened not under acceleration but with partial or off throttle.
At first, I thought it was the wheel bearing, but then it did not do it all the time. I ended up researching on this board and diagnosed it as my calipers. I ended up rebuilding my calipers and noted that one piston was stuck and that pad was down to 20% while the others were all 85%. After the rebuild, it stopped doing it.
I ended up rebuilding the rears and noted that another piston was stuck back there also that was grinding down another pad to 1mm. Take a look at your pads or discs and see if there is abnormal wear on them.
If you're gonna do a rebuild, try the brake wizard provided here by pelican. Great tool to order parts in one shot. It is a dirty job, but very worthwhile DIY. Good luck!
Old 11-05-2008, 09:19 PM
