911t
novadia's Avatar
k&n vapor kit dumb newbie question
please don't laugh at the newbie, but I want to get the k&n watershields for my 1969t and I have a vague idea about what the vapor kit is. Could someone tell me what it does and how it gets installed?
1995 993 C2 - Sold
1976 911 Backdate w/3.0 - Sold
1969 911t - Sold
1965 912 - Sold
Old 11-09-2008, 03:02 PM
When you remove your stock air cleaner assembly you will be left with some unattached vapor emissions hoses. The vapor kit will tie them together and then to the water shields thus giving your engine compartment a more tidy appearance and routing the emissions to the carbs. The kit comes with printed instructions. The kit is worth getting. Very easy to install.
Have fun.
Gary
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 11-09-2008, 03:13 PM
911t
novadia's Avatar
What are the gauges leading from the carbs that I see in so many pics?
Old 11-09-2008, 03:18 PM
Forgot. Richard Parr at PMO has everything you need.
gary
Old 11-09-2008, 03:20 PM
PCA7GGR's Avatar
fuel pressure
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
The only gauge that I can think of in the engine compartment is a fuel pressure gauge. Richard Parr at PMO has these too.
Gary
gary
Old 11-09-2008, 03:23 PM
While the PMO hose kit will satisfy the needs of the oil tank vapor recovery system, I'd recommend installing (later, if not now) a oil breather/catch can in the path between tank and carbs. This helps separate liquid oil from fuel vapors. Under some driving and engine conditions (high g loads, full/over filled oil tank), liquid oil will be forced through this path into the air filter housings. A full smoke screen following your car is one telltale sign.
Unfortunately, most catch can setups for a 911 are DIY with the appropriately sized hose fittings and mount.
The archives will show many variations of this theme as will contributors to this thread.
Sherwood
Old 11-09-2008, 04:14 PM
911t
novadia's Avatar
thnx guys anything else that should get done "while I'm in there"
Old 11-09-2008, 06:52 PM
