Breaking up after 2 months sitting
Good Day. After a short period of time, 60 days of not running, other then a single start of just idle, I have an issue. The car starts and idles fine. Huge mis when throttle is giving. Partial or full, same thing. I am thinking fuel. I put Stabil in with a full tank in late November. Ran half the tank down and it sat for 60 days half full. I have added 5 gls of fresh fuel along with red line fuel system cleaner. The car is now idling in hopes the fresh fuel will work it's way through. No change.
Fuel filter and check plugs?
3.2 1984 109k miles
Thanks for your help. Dave
Old 02-27-2016, 01:08 PM
can you put a long screwdriver on each injector and listen for clicking?
Rick
88 Cab
Old 02-27-2016, 03:37 PM
Hi Rick, yes will do in the morning.
Old 02-27-2016, 04:15 PM
6 cylinder symphony
Did you have the fuel injectors rebuilt?
I recommend Witchhunter.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 02-27-2016, 04:17 PM
Keep running it that happend to me once it took a tank or so to really clear up.
Old 02-27-2016, 04:23 PM
Injectors have not been redone to my knowledge. I have had the car since 55k. 16 years. May need it I suppose. Will look closer
Old 02-27-2016, 05:41 PM
I can here all six injectors ticking with a long screw driver. All sound the same.
Old 02-28-2016, 07:52 AM
6 cylinder symphony
May not be that they aren't working. Could be partially plugged.
I'd send them off for cleaning. While that's going on, I'd also change the fuel filter.
Again - I recommend witchhunter. They give a nice before and after readout of your spray pattern/efficiency.
'84 3.2 Targa
'89 964 Coupe
Old 02-28-2016, 08:14 AM
