speedometer 1984 911 targa
my speedometer works, but it quite recording number of miles traveled. how can I fix this?
Old 11-05-2008, 02:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check in the Tech Articles or get Waynes book he details how to.
Try the search function,it is your friend
'85 Carrera Targa
PCA/POC
Old 11-05-2008, 05:02 PM
The 'thing' that doesn't work is called an odometer. That will help in your search.
A common failure.
Old 11-05-2008, 05:31 PM
Thanks for your "clarification" (odometer) and suggestion that I try the "search function". I'm embarrassed to admit it, but I can't find the 'search function'. This is the first time I have used this website. Can you tell me how to find this and on what website page? Thanks!
Old 11-05-2008, 05:52 PM
3.2 CAB's Avatar
What part of Texas???
I had a shop in Houston refurbish mine, plus replace the odometer gear that was starting to act up. Same day service. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-05-2008, 11:44 PM
s_chev
s_chev's Avatar
Send a message via Yahoo to s_chev
I bought the replacement gear for under $30 and replaced it myself. Go check out
http://www.rennbay.com/odometer-gears-c-32.html
and also check out their tutorial page.
http://www.rennbay.com/odotutorial.html
It's written for a 928, but once you get the speedo out of the dash, the instructions are the same. I also sent an email when I had a question and they responded right away.
Give it a try. It took me about an hour because I was taking pictures.
It's simple really. Shoot me an email if you have any questions.
~Steve
s_chev@yahoo.com
Old 11-06-2008, 12:31 AM
To Search,
Go to the Blue toolbar (above the "Post Reply" button), to the word search. Type in "odometer". You'll get a long list of threads about your subject.
Old 11-06-2008, 09:08 AM
Detached Member
Hugh R's Avatar
Several threads I've read said it's worth sending it to someone, even if you're a DIY. North Hollywood Speedometer. $100, cleaned, repaired, dial repainted and calibrated.
Hugh
Old 11-06-2008, 10:00 AM
