-   -   Temp Switch Wire Question (http://forums.pelicanparts.com/porsche-911-technical-forum/439946-temp-switch-wire-question.html)
brads911sc 11-07-2008 12:02 PM
There is a Temp switch on the cam chain cover of CIS cars... Mine is an 83 SC. The switch has two wires that connect to it.. The male end on the switch has a round raised button on it (see attached)
Here is my issue, the terminal broke off the wire. Where can I find the wire terminal end. I cant find one anywhere that will slide over that raised round button. Any ideas?
http://forums.pelicanparts.com/uploa...1226088153.jpg
x98boardwell 11-07-2008 12:22 PM
Response
A normal female spade connector that slides over the male connector should work. You are just sliding it from the side of the round raised circle.
This is a quick link that I found on Google to show you, but you can find them at any auto parts or hardware store.
http://www.wiringproducts.com/index1.html?lang=en-us&target=d44.html&gclid=CJTMv9_x45YCFSJIagodHAxmO A
You can also see an example of how it would connect in this photo below. a similar connector is just below the flywheel on the right. You can see that the connector covers up the round circle and slides on sideways.
http://forums.pelicanparts.com/uploa...1226089328.jpg
Hope this helps,
Bryan
brads911sc 11-07-2008 12:26 PM
Thanks. I feel stupid now. Can install SSI's, Rennaire system, new clutch... and i get hung up on a terminal end.
x98boardwell 11-07-2008 12:42 PM
No worries
Best of luck with the car...
