Removing Oil Spots in the Driveway
My friend told me, "911's don't leak oil, they mark their territory." I found this hilarious, my parents find it abhorent now that they are in the process of selling their house. There's a good couple spots on the driveway and in the garage that they would really like me to get rid of. Are there any trade secrets or amazing products that anyone knows of that will help get these out?
Aaron Z. 1980 911SC 262K on the clock and peppy 1969 911T hot rod with AWD dreams 1979 FIAT Spider rusty, not trusty (yet) |
Band.
Get a big bag of CHEAP kitty-litter (no fancy stuff), and a pair of big work boots.
Spread the kitty litter on the oil spot, let it sit for a while, and then walk all over it with the boots, twisting and grinding it into the cement. Do this untl you've covered the whole area you're trying to get at, and sweep up.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Spray some engine degreaser and let it sit for 15 mins before hosing off.
2007 997 TT 1992 500e |
It is slightly (read:quite, oops) soaked in. Will the kitty litter be able to pull a little bit out of the concrete do you think?
ohh degreaser, good stuff...
I've had pretty good luck using Simple Green. Scrub with a heavy duty nylon brush and hose off. It's biodegradable too so is a little more friendly to the environment.
There is a powdery orange type of floor cleaner that shops use to clean their floors i dont know what its called but the stuff works great. Id stop at a small independent shop (the kind without a-holes) and ask what they use. Maby they'll even let you have a scoup of it
82 SC , 72 914 |
Band.
If not, +1 for Simple green. I've tried the engine degreaser too, but it's a more caustic experience.
Powerwasher.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Soldier of Fortune
Muriatic Acid (diluted, if you're chicken). Use caution.
MEK (methyl ethyl ketone) will de-grease/de-oil ANYTHING, but beware, it will dissolve tarmac and any paint, it evaporates quickly. Don't get it on your hands.
1997 Boxster SOLD 1999 R1100S SOLD 1988 Carrera 3.2 |
Less brakes, more gas!
Depends on what the surface is made of...
I have pavers that were sealed on the driveway and one time changing the oil I forgot to open the air hole in the drain pan... I was only gone a few seconds before that 'Oh S!!T' moment, but the oil was every where.... After getting all the wet stuff up with paper towels I used the cheap kitty litter to get the rest up... or most of the rest. Now, here is my secret method... go buy a bottle of Dawn dish washing liquid and a stiff brush. Boil some water and throw it onto the stain. Then pour a bunch of the dawn on the stain and scrub a dub dub with the stiff brush. Let it sit for an hour with the soap on it. Come back with another pot or three of boiling water and rinse. To this day I have a really hard time finding the spill... for concrete use the acid... I'm not sure it would be good for asphalt though. Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
heat, get it hot.
then pressure clean it for quite a while with tightly focuse nozzle with at least 1600psi. then pour phosphoric acid on and brush it, watching it eat the lime in the concrete. then rinse with water. go in steps if it foams too fast. experiment with the acid. muriatic acid is ok but not as powerful. if that doesn't work, paint it. |
Someone once told me to use carburetor cleaner on concrete oil stains, I've never tried it...
Mitch Leland "03" 996 C2S-LS3 V8-480 HP "84" 911 Turbo Look-Sold w/ found memories |
Slippery Slope Victim
Castrol makes a Purple colored (bottle & product) degreaser that is great.
I've used it on both concrete and brick pavers with very good results.
MikeČ 1985 M491 |
+1 on the Simple Green.........with a kicker.
Soak the spot in the Simple Green, let sit a few minutes, scrub with nylon brush a few minutes, put down the Kitty litter and let it soak, sweep it up.
Sean M '77 911S Targa Ice Green |
Slumlord
Assuming it is concrete spray it with WD-40 and cover it with a plastic sheet for 48 hours. The pour on the kitty litter and wait a few days before you sweep up.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Forced Induction Junkie
Yep, it works for small spots. Two sprays on the spot and it's gone.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Instead of an oil stain you will get a "to clean" stain.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
