Opinion please on 3rd gear problem -middie.
I have a 76 911 and I am like a lot of you.. I could never own a new porsche.. too rich for my blood.. actually I could but choose not to..
I do all of my work. I have rebuilt motors. But NEVER a trans. So my poor little porcha crunches into third gear down and up.. unless I double clutch.. I replaced the fluid with spectum or whatver its called and it made no difference.. but the blue color makes me feel good. ![]() Problem is is when I want to drive the car in a spirited fashion I forget about the double clutch.. I dont drive the car much but when I drive it I'd like to play a bit.. I used to race a ton and know how to match revs and all that crapola but it doesnt matter it still crunches and when I forget its a nasty crunch at high R's. Okay so my question.. How hard would it be to crack the transaxle and make this repair myself? I assume Id be doing all the syncros. How many special tool will I need? And what is the likely-hood someone like me could pull it off? And more importantly Id like to know if you all think I should just live with this rather than do the work. Maybe put something on the dash that says double clutch third and let it go? I would love to hear from a shade tree who has gone for it and done this job... I would also like to point out that the 76 is probably the cheapest 911 you can buy and it is a joy to drive for anyone wanting to get into a fun galvanized 911 with no rust. thanks for your advice.
JP '76 911s Ice Green Metallic bone stock |
Formerly bb80sc
Start with the simple stuff. Replace the shifter and coupler 'bushings'. Check/replace your motor/tranny mounts. Make sure the shift lever is properly aligned.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited Last edited by Vipergrün; 11-08-2008 at 05:42 PM.. |
I've done all the linkage.. but not the motor mounts or tranny mounts. In experience mounts wont cause a this sort of problem unless its during high speed cornering.. correct me if I am wrong about that. Isnt the double clutch a dead giveaway that this is a syncro?
Max Sluiter
Sounds like a syncro to me. I think your diagnosis is correct and you will be going into the gearbox.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
