73 MFI to CIS when did it change
Im just curious as to when they made the change from MFI to CIS. I have a 73, but not the original engine. I assume it originally had CIS as thats whats in it now.
My serial # is 9113102450 The engine that is currently in the car is from a 72 #6122522. Im having cold start problems and I'm waiting on a few parts from pelican to hopefully sort this out. I'm also going to do a leakdown ect to see where I'm at. Anyway, I'm planning on at least buying a correct year longblock or case at some point and want to make sure I pick up the correct type.
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
I don't have your answer but my '72T has MFI and the build month was 11/72
'73 914 2.0, '74 911 Coupe, '74 911 Targa '78 924, '84 944, '86 944 Turbo, '84 911 Coupe '84 944 (current), '96 993 Coupe (current) '73 911T Coupe (current) '88 930S M505 (current) |
Porsche started using CIS for the 911T in the middle of the 1973 model year. In 1974 both the 911 and 911S had CIS and the 1974 RS Carrerra had MFI. All '72s had MFI.
If you have a '72 then you should have a MFI Car unless your engine was replaced. Besides the serial number on the engine nearby is a code that reads something like 911/xx. That will be the code for your engine type. This site can help you decode the whole mess: http://www.elferhelfer.com/fzident/fzident72-73.htm From this site, it shows you have a 1973 911T Coupe Body and a 1972 911T engine but since CIS did not come to Porsches until mid 1973, that was done after it left the factory. Also, FWIW, your car came with Factory Air but where are the compressors, condensers etc? Another bit of help: Quote:
I don't think your car is a 72. You don't have the oil door on the right rear fender.
Lotus 23 Lotus 7 TVR Vixen TR3 914-6 Clone 914-4 X-Runner |
I pulled the AC parts off as the hose's were rotten and nothing worked. How could you tell it was origninally a AC car?
Glad to help. How did I know you had AC? Easy. If you look at your coil, there is a mounting plate that moves the coil closer to the engine. Porsche did that to avoid the coil hitting the Engine Lid condenser. If you really want to get into the tiny details, visit the folks at the Early 911S Registry BBS (http://www.early911sregistry.org/forum/index.php)
Warren Hall Student
You can also see part of the bracket for holding the compressor next to the oil pressure sender.
The CIS system you have is definitely from 73.5'. That's the only year that the intake runners were made from steel. Starting in 74' they were all made from cast aluminum.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
I think what you are looking for is 2.4 liter 7R case as these where the ones used on the 73.5 CIS motors. All the later 7R cases will be a larger bore for the 2.7 liter motor. I have one of these cases listed on e-bay but I don't know the case number at the moment. If you are interested I can check the case on Sunday.
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
