Throw it on the ground!
Pilot bearing replacement procedure for G50?
Have searched but can't find how to replace the pilot bearing. Engine is out on stand and flywheel is accessable.
How do I remove the old pilot bearing?
Do I need to remove the flywheel?
How do I press the new bearing in?
Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 11-08-2008, 04:21 PM
I just did mine with the flywheel removed. I was able to tap it out with slightly smaller socket. Back in the same way after putting the new bearing in the freezer over night. Note that it is flush on the engine side I believe and protruds a bit on the other. You are supposed to replace those bolts if you remove them too. Here's a tech article and you might check a Bentley. Ken
Ken in Greer, SC
88 Carrera Coupe
98 C2S Coupe
Old 11-08-2008, 06:40 PM
zbph10's Avatar
Ditto, pull the flywheel, use a socket to remove/replace the bearing and replace the bolts.
1987 911 Coupe-Current ride
2007 997TT-Sold
2006 997 C2S-Sold
1991 964 Turbo-Sold
1987 911 Targa-You never forget your first
Old 11-08-2008, 10:18 PM
