Replace/Rebuild a working alternator with 100K?
I removed the alternator from my 77 2.7 in the process of doing some other work, and now I'm wondering if it makes sense to do a little preventative maintenance and either rebuild it or replace it while it's out. The alternator is the original unit and has a little over 100K on it. From what I've read, I shouldn't expect it to last too much longer. I'm not sure how this might factor in, but I also plan to go with an Electronic Ignition setup (Clewett/Electromotive) sometime soon (higher output needed?).
Reading some of the posts here, some recommend rebuilding my existing unit, while others say simply buy a rebuilt from Pelican. The best quality choice seems to be the new Australian built units, but $640 is a bit steep. It also appears from Pelican that the direct replacement for my 77 with the external regulator is NLA, and that I would have to "upgrade" to the Paris Rhone unit which has the built-in regulator (and the extra parts needed to make this work). Is this a good idea, or am I better off simply getting my existing unit rebuilt and sticking with the external regulator? Should I replace the regulator as well if so? thanks, Frank
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
3.4 Bigger is better
Take it to a local shop and have it rebuilt. I had mine out several years ago and took it back to the shop that rebuilt it 9 years before. They checked it out and said it should be good to go a lot longer and no charge. Also had them refresh my starter during my engine rebuild.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
some say the internal regulators usually fails due to engine heat and contributing high heat issues.
100k miles is a lot of miles.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
#8 is a noise suppressor that may cause regulator problems. Most times it can just be pulled out of the circuit without issues.
Thanks for the responses. And Ronin, thanks for the diagram. I wasn't sure if the internal regulator was considered an improvement over the external design - at least for where these things live in a 911 environment.
I'll probably go the route of simply having mine rebuilt. So, from what I've gleaned during my searches, what I should ask the shop to replace are the Slip Rings and Bearings, right? Anything else? Are the slip ring brushes/contacts typically replaced along with the ring? Now I need to find a shop here in Austin. thanks, Frank
I would go to a truck starter and alternator rebulder.
at 100k miles I'd replace diodes with good ones built for high heat. ps: marine rebuilders are good around here because marine alternators are designed to consistantly run at amps that would cook a car alternator.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 11-09-2008 at 08:23 AM.. |
Go for the rebuild but I will disagree and say that 100K is not that bad on an alternator. On my daily driver I am running well over 140K on the original alternator. Now it might bite the dust but it has gone 40% longer than you guys say is lots of miles. Then again my daily driver revs up to a maximum of 2500RPM on a daily basis and rarely sees redline of 5250RPM. On a Porsche engine you could be holding 3,000-4,000RPM going down the highway quite easily. This might cause more wear as that is about 50% more RPM than my alternator runs at. Counter to that argument is that my modern car with tons of electronics and stereo is really running that alternator down! OH BOY LOTS TO CONSIDER! GET IT REBUILT!
Like said above, take it to a local shop (look in your Yellow Pages under Alternators), get it rebuilt, should be maybe $100 and you'll be good for another few decades.
Air Medal or two
Well if it were the Space shuttle with a TBO then maybe,...But they are EZ to R and R so I would wait till the day
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
ssssoooo much easier to do when the motor is out... a little PM could save a lot of under the hood work later...
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 |
The alternator is easier to R&R with the motor out? I find it irrelevant whether the engine is in the car or on the floor to deal with the alternator.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
An engine stand or leaning into an engine bay ... the same level of difficulty ? maybe .. whats your point? IMO... OK STEVE... IMO it is easier to do with the freakin alternator already removed from the freakin motor... What is up with some peeps on this board always looking to pick someones post apart....
Either way, I see a $100 as cheap insurance from having to go in and do this again any time soon. Frank
Get a grip, Tony, I'm not simply trying to "pick you're post apart." I'm simply pointing out that you may be giving somebody who doesn't know better bad advice when you say "ssssoooo much easier to do when the engine is out." that's a vast--or maybe I should say vvvvaaaaast--exaggeration. Nobody should think twice about removing and replacing their alternator by simply leaning into the engine bay. I've done it half a dozen times.
There are a few things I like to do when I pull a motor and have it on an engine stand.. check the clutch, PP, TO ... adjust the valves and R+R the alternator .... if its history is unknown to me... I like to blow air through the cam oiler tube to make sure none of the holes are clogged..
YES these things can be done with the motor in the car ... but why not do them while the motor is on the stand when I am usually waiting for parts anyway... Perhaps I did ooovereact a bit and maybe I did put one or two many o's on my so... But my wife just read your post Quote:
I think what Formerly was getting at was, "don't pull the motor to get at the alternator."
That said, doing anything to the motor is easier when it's out and on a stand, but no one would pull a motor for the alternator alone. |
Air Medal or two
I "think "If you post here you want everyone's opinion ? so that's what ya get.
Tony, don't feel bad, I still get teased because I once posted that replacing a 911 windshield was so easy my wife could do it.
I still see threads about windshield replacement in which somebody is sure to post, "take it to Wilkinson's wife, she'll do it."
Air Medal or two
My G.F. Always does it. LOL
Boy, this thread sure has become interesting
. I sure didn't intend to stir up any ill will among fellow members. I do appreciate reading various points of view (if constructive) because I sometimes learn that there may be more than one way to achieve the same result.Perhaps a bit more information here will help. I did not mention this initially because I didn't feel it was relevant to the question at hand, but things seem to have wandered a bit... So the motor is out (on a jack, not a stand) for some various other (mostly non-motor) work I am doing. And the alternator is out because I am sending the fan and fan housing off to be Nickel plated. So, the main question was since the alternator was sitting in my hand already, should I have it rebuilt given its age and mileage as there will be no extra labor in doing this now other than the trip to/from the shop (it sounds like the consensus is yes). My apologies for any confusion/tension I may have caused. Regarding the picture I mentioned earlier of a better view of the alternator wiring connections, here you go... ![]() Frank
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 Last edited by frankc; 11-09-2008 at 04:20 PM.. |
