I'm sure she's fine digger!!
the muffller is held on by straps under the car, not those two bolts in the rear corner of the engilne compartment
Join The Club
Welcome to the club... "Here's your sign"http://forums.pelicanparts.com/suppo...leys/silly.gif
Many, many people here are in the, doing stupid things thread. Hope things go better the next time! Good luck!! Tony.SmileWavy |
Thanks for the replies.
If the shift rod is bent, what is the fix? Does the tranny have to be opened up? Come to think of it, it is a skosh hard getting into 2nd. The bonehead move was the result of my attempt to remove the a/c mounting bracket from the case. I'll post a pic soon.http://forums.pelicanparts.com/suppo...leys/silly.gif |
Have you changed the engine oil yet? We get a lot of first time oil change disaster postings. Like using an 8qrt catch pan, when the engine and tank may hold 12qrts or more, etc. Good luck with it Matt!! Tony.
What all was "connected" when this motor hit the ground?
Best, Doyle |
Everything was connected and the motor didn't hit the ground. It dropped but stopped short of hitting the ground. |
| All times are GMT -8. The time now is 11:53 AM. |
