spsfiend's Avatar
Brake Lights no worky. help!
I just found out today that my brake lights don't work! Checked the fuse and it's good. The driving lights work but when I press the brakes, the brighter brake lights do not go on?! Is there a sensor that the brake pedal triggers? Someone please help!
the third brake light in the rear window doesn't work either. I checked and even replaced the bulbs and still same prb.
I have a 1987 911 Coupe.
Thanks for the help!
Gerry
Old 11-09-2008, 09:04 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh Man,
It's probably the two Brake Light Switch (BLS) at the Master Cylinder.
Some of us un-lucky P-car owners have either slow brakes lights or in your case complete failure.
You can replace the BLS's but most likely the symptoms will return.
I have a fix if you need it.
Do a search and you will see my findings.
'85 Carrera Targa
PCA/POC
Old 11-09-2008, 10:10 PM
spsfiend's Avatar
Ygpm!
Old 11-09-2008, 11:45 PM
rnln's Avatar
Gerry,
This issued discussed several times before. You might want to read this thread.
One or Two Brake Light Swiches???
or this too.
brake light switch replacment
Fat butt 911, 1987
Old 11-10-2008, 01:50 AM
DRACO A5OG's Avatar
PMd you back Gmail is down
'85 Carrera Targa
PCA/POC
Old 11-10-2008, 06:36 PM
