I did search... Really... Partial engine drop Qs
I thought a search would pull up lots of info on this, but apparently not.
I keep hearing "partial engine drop" and it sounds sort of obvious. However, can someone more precisely define what constitutes a partial drop? I am intending to put in a new engine sound pad and a partial drop seems to be suggested for a good job. Thanks! |
not fully removed
You basically disconnect fuel lines, electrical connections, shift rod coupler, etc. Then by removing the rear engine mounting bolts, and supporting the engine with a jack, the engine can be lowered (partially dropped.)
Not worth the effort.. always easier to drop the whole engine, not a big deal .. I'm doing it again this weekend by myself
Don't forget to drain your oil and remove the line from the tank.
Thank you for the replies. I had been wondering if there was some "in-between" stage in which only some of the disconnections normally done for a full drop would allow the motor to come down a few inches, but it seems like you must disconnect pretty much everything you would do in a full drop anyway. Thanks for taking the time, Allan
I did a partial drop to replace the cross brace that the rear mounts bolt into.
I unbolted the mount, unbolted the a/c compressor and belt for about a 4" rear drop. This gave me enough room to wriggle the cross bar out and put in the new rennspeed ss rsr bar. All the threads I saw were more involved, such as undoing the shift linkage in the back seat assess hole, but I got by without doing any of that. Bill K |
Maybe I've been doing it wrong, but when I wa working on my CIS, all I did was undo the shift coupler and the two engine mount bolts. Then, I just let down my jack SLOWLY to make sure nothing got stressed. I didn't have any problems.
You'll need to clean the area, perhaps touch up the paint and use glue for the new pad. In other words, you'll need room to do it. If you only do a partial drop, you'll be cursing a lot and it won't turn out nice. You may want to wait with this until the engine has to come out for another reason like clutch etc. :) |
| All times are GMT -8. The time now is 10:58 AM. |
