Gear ratio's for a 915 for the street
Any recommendations for a street 911 3.0 915? doing a rebuild now so if I'm going to change gears now the time. Facts:
It is a 3.0 engine in a 1975 carrera. ZF limited slip at 60% Org. magnesium case CIS suspension is fully dialed The car is a street car with limited track driver ed. ( Laguna Seca, Sears point) What I'm looking for is quicker acceleration, but flexibility in the power band for the trip over to the beach (mountainous terrain) thank in advance Craig |
'75 US 911 & Carrera came w/ 915/40 5speeds. Stock gearing is very good for most purposes
![]() You have nice progressive & reasonably sized drops and a reasonable speed in each gear. If you don't have a lsd that would be a great upgrade, best for the described use would be a GT 40/60, but a ZF 40 would also be good
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 11-11-2008 at 11:10 AM.. |
Thanks again Bill, I have a zf in place now, is the lock adjustable? I think the last time I had the Trans rebuilt it was at 60% It is great, hammer it and it will go straight!
How about any internals for durability? Craig |
I feel stock gearing dealing with speed limits is nice. I never have to race engine or lug it. A nice 2.8-3.2k rpm keeps engine clean and cool.
I also have wevo parts so it'll support a 250hp 3.4
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
the down side of higher lockups is increased understeer and potential for severe handling issues on ultra slippery surfaces, you really do not want to hit an oil slick w/ an 80% unit later units used in 964 up also have an asymmetric ramp setup that alters lockup differently on acceleration or deceleration. these are very much improved units, performance wise over the older straight units because you can have the lower % for acceleration and higher on braking where you want the stability that lsd imparts to the chassis Wevo has a very nice 1 piece intermediate plate and reinfoced side plates, alternately late 915 side plates can be used, g50s have available steel syncros and billet shiftforks bot are extremely expensive, not sure if they are available for 915s
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 11-12-2008 at 10:28 AM.. |
AutoBahned
"flexibility in the power band"
- drive the road a few times and note the mph, gear, rpm and whether a curve or up or down hill - do a few times and in each direction record notes on a voice recorder - reduce to writing -- analyze... it's obvious you want something other than what you have now... but are you willing to do the work and pay the $$ to change? |
I guess what I'm after is a way of "quick n ing" the 3.0. with the reliability of my rebuilt CIS system
in place now (7 and 8's -16's) alum pressure plate |
What you need to understand is that it's all a compromise, sure you can gear lower
here's an an example of a really tight close ratio 915 race box ![]() 39mph@2000 69mph@3500 137mph@6500 and another for the SC/RS, also a race box ![]() 41@2000 72@3500 134@6500 and compare that to your stock 915/40 46@2000 80@3500 149@6500 what is gained w/ the lower geared boxes? acceleration in gear, the engine can be kept w/i a few hundred revs of max hp most of the time what is the penalty? increased frequency of shifting(when you shift you are slow), increased rpm@ cruise(compare the 3500rpm #s then think what your car is like @ 3500), a narrower range of speeds in a gear(you are more likely to have to shift at an awkward place or time) increments of 10 mph difference in top make a major difference in the feel of a trans.
