Band.
Not enough advance = Dirty Distributor?
On my '83 SC:
Timing specs with vacuum lines plugged SHOULD BE 5 BTDC at idle, and 25 BTDC at 4K rpm.
Right now, I get about 6 BTDC at idle, and only about 20 BTDC at 4K RPM.
So . . . . Is it because my distributor internals are dirty and sluggish and not advancing enough and I need to clean up and oil the distributor?
I want to make the 4K advance 25 BTDC and just forget about it, but another side of me wants everything to be "correct."
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-17-2008, 02:49 PM
Most likely, your springs are worn and the mechanical advance is coming in at your idle speed. In other words, your real static timing is 1 BTDC. My advice is to put a few drops of oil under the rotor and set the high speed timing to 25 BTDC. Then leave the vacuum retard disconnected and plugged and reset the idle speed to 950. Then set you FV duty cycle (mixture) to 30-40 on the 4 cylinder dwell scale.
Paul
Old 11-17-2008, 03:03 PM
jtfreels's Avatar
Jeremy,
How is the car running, any issues? Just wondering if you have any symptoms, I had some starting issues with my 82, had to replace the magnetic pickup inside the distributor, cleaned it with out removing to many other parts.
Now with it all back together it stumbles badly from 2k to 3k rpm with the advance hooked up. With out the advance a very slight stumble.
Jay
2002 Boxster Speed Yellow
Old 11-17-2008, 06:55 PM
Band.
It runs fine - as far as - distributor issues go. It's not too fast, because I think I'm not getting my full mechanical advance.
It's also run hotter than I want (230) which I think is a combination of a few things, one of which may be improper timing advance, I guess.
There's a cold stumble, but again, it's a CIS thing, I don't think its anything to do with my dizzy.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 11-17-2008, 06:59 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Jer,
I"m dinking around with my timing right now too,,I am getting too much advance I think.
You're giving up some HP without the advance.
Have you looked at getting a digital WUR ?? I love mine..
T
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-17-2008, 07:10 PM
