Shift knob wiggle
This last week my shift knob has begun to rotate in my hand a little bit- maybe 1/8 turn to the left and right. Does not seem loose if I pull up or push down on it.
Is there something that I can adjust to retighten it so it does not wiggle in my hand while driving? thank you erik dorsch
87 911 coupe "Katy" Summer Yellow Linen Mahogany interior 04 Pilot "The Pilot" |
Mine does the same...
any advice x2?? -Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 |
This Way Up
On the G50 shift knob, you gently pry up the disc with the shift pattern. This exposes an allen bolt, which you can tighten up to eliminate the wiggle. Pop the shift pattern back in and you're done.
I am missing the bolt... any idea what size it is , and can I get a replacement at the hardware store? Don't mean to hijack... but it seems related.
Thanks, Emerald
'88 911 coupe, Laguna Green Metallic (sold)95 993 Aventurine Green(sold) 97 993 C4S Vesuvius |
thank you very much rdrr
e3photo- I can take a picture or try to measure when I do mine (likely this weekend) if you would like
