-   -   Getty Design R-type amber engine shroud (http://forums.pelicanparts.com/porsche-911-technical-forum/441933-getty-design-r-type-amber-engine-shroud.html)
onboost 12-01-2008 08:51 AM
Originally Posted by andyjboy (Post 4313138)
I have one of Damon's amber fan shrouds on my engine - only required very minor tweeking for a perfect fit ...
Where can you find one of "Damon's amber fan shrouds?" Cost?
Since we're on the topic.. does anyone have any experience with the various amber/fiberglass sheet metal tin replacements. Any better than others?
GG Allin 12-14-2019 06:23 PM
Due to the difficulty described here that's involved with cutting these shrouds to make them fit, I wound up cutting two or three of my six intake holes a little big. Is this going to cause cooling problems? Mine is not a Getty, but did require lots of cutting.
skinnerd 12-14-2019 07:54 PM
I totally agree with Damon's fan shrouds being the best in town.
His company: Series 900
No offense to the originator of this thread, but his shroud does not look very "amber" to me.
It's more of a washed out off grey.
Perhaps it's just the camera?
Here is my Series 900 amber fan shroud that I put on my 2.7 RS MFI engine.
Now that's what I call amber!
As far as I know, very little if any work was required to get it to fit.
It looks great IMHO.
http://forums.pelicanparts.com/uploa...1576381690.jpg
http://forums.pelicanparts.com/uploa...1576382008.jpg
911pcars 12-17-2019 09:56 AM
All shrouds exit the mold needing edge trimming.
Most come out of the box looking like this (hopefully not distorted):
http://forums.pelicanparts.com/uploa...1576602174.jpg
However, the final fitment requires install holes as well as six cutouts for the intake system (EFI or carbs).
http://forums.pelicanparts.com/uploa...1576602621.jpg
A Dremel tool with carbide cutter and sanding drums:
http://forums.pelicanparts.com/uploa...1576602896.jpg
http://forums.pelicanparts.com/uploa...1576603653.JPG
http://forums.pelicanparts.com/uploa...1576604005.JPG
http://forums.pelicanparts.com/uploa...1576604481.JPG
If an amber shroud appeared on your recent rebuild, someone spent time for a proper fit. Add a few hours onto the rebuild schedule.
Sherwood
GG Allin 12-17-2019 09:59 AM
^^ Which shroud is that? ^^
I'm a little less worried, your intake gaps look similar to mine. I suppose once my carbs are back on it'll be sealed up a little better.
911pcars 12-17-2019 10:06 AM
The camera angle and shroud height above the intake flange makes the openings appear larger than the gasket. If possible, I suggest minimal air gap to reduce potential airflow loss in this area. Some U-shaped rubber molding around the inside of the opening can help.
silver911rdb 05-25-2021 10:40 PM
I know this is an old thread but are Series 900 shrouds still the one to get? I’m in the market and have called and emailed Series 900 but haven’t gotten a response. Wondering if they’re still producing them?
H-viken 05-25-2021 11:44 PM
I got the one from EB Motorsport. Rothsport carries them in the UShttp://forums.pelicanparts.com/uploa...1622011458.jpg
GG Allin 05-26-2021 08:55 AM
He lists them on Ebay.
