Steering Rack Rebuild?
While doing the tie rod upgrade on my 82 SC I pulled the rack to freshen it up. It was pretty dry inside so I replaced the bearings and am in the process of putting it back together. Everything is good until I put the pressure block back in. Once I add the shims, spring, and tighten the cover, the rack becomes very stiff and takes some force to move. There really isn't much that can go wrong with it though. Has anyone experienced this before? Any suggestions?
Chris
82 911SC |
I have no experience in there
may I ask bearing and other part numbers and did you source them from pelican?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
The only 2 parts that are easily sourced are the bearings which I picked up from a local industial bearing supply house in Miami. Blair Bearings Inc, 305-233-3020
Torrington HK 1712 (needle bearing) SKF 6202 (ball)
82 911SC |
Steering Rack "Rebuild" Procedure
SC Steering Rack DIY Bearing Replace The above 2 links will help. Notice that there is a "lash" adjustment. You may be binding up the gear when fully assembled and tightened down. |
I think the spec is 6 or 7 inch-pounds to rotate the pinion once it's bolted up. If you're just using your hand on the pinion shaft, it will be difficult to turn.
Correction: 113 - 198 in-oz, which works out to 7 to 12 inch-pounds, measured at the steering wheel. So if you take 20 - 30% off for the 2 u-joints, 5 to 8 inch pounds at the rack seems reasonable.
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" Last edited by burgermeister; 11-06-2008 at 03:32 PM.. |
My car is a 1970 and my steering rack is different than the ones shown in the links above. Im restoring the whole car and I also want to do the rack. Thanks in advance.
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
