Shifter boot replacement without knob removal possible?
Hi there,
...since I don't want to destroy my original 915 shift knob by taking it off, anyone ever tried to replace the rubber shifter boot by pulling it over the knob (heat, lubricating etc). Just curious and running out of projects.
Old 11-24-2008, 04:28 AM
Gerko, it's too easy to remove the knob. Place an open end wrench under the knob and strike the body of the wrench near the knob. It will yield, perhaps explosively (don't place your head above the knob).
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 11-24-2008, 04:55 AM
...thanks Howard, I am aware of this technique but am afraid to try due to the fact that the knobs are NA. I have done a search and have read that sometimes the knob breaks.
Old 11-24-2008, 05:41 AM
Don't break a good original factory knob that's NLA. Remove your console and shifter assembly and work from below to swap the shift boot. Clean everything up and re-lube the cup, etc., while you're in there. It's more work, but you won't be destroying something that's gotten expensive to replace.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 11-24-2008, 07:11 AM
Somatic Negative Optimist
Gunter's Avatar
Only if you go wild with excessive force.
I tried a 15 mm open-end wrench and tapping from underneath, no go.
Then I sprayed penetrating oil from underneath into the inside of the knob and tried again.
Success!
To get the oil inside the knob, you'll have to use the small long extension that comes with most spray bottles.
Also, I used a 4 lb hammer tapping on the wrench; short decisive taps.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 11-24-2008, 11:34 AM
