what trans is this?
it's on CL seattle. is it a sporto? doesn't look like a 915 to me. what are those doodads hanging off the front?
Fuchs w h o r e
901
Looks like a type 911 from '70-'71 with an earlier 912 mount.
What are the type number (911/0x) and the transmission number (7xxxxxx)? These are stamped in the casting under the differential area. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
It's a mag. case 901/911 looks like it has a 912 mount on it...
Tony Proasi 1969S 1957 VW Pickup |
What is the odd little cast bit on the transaxle mount?
angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
hi Grady. can't get the numbers yet. I've emailed the guy. what are those things on either side at the front? Don. |
Don,
There are numbers cast on the side that are casting numbers. They will typically have the form 911.xxx.xxx.ZR where "Z" is the casting revision. This probably should be zero in your case. The type number and transmission number are actually stamped into the metal. There are two version of the type 911 casting; one with the numbers stamped in the rib under the differential and the other with a purpose rectangular pad cast under the differential. For a type 911 transmission, the type number should be 911/00 for a 4-speed or 911/01 for a 5-speed. There are also types 911/80 (Standard - special option), 911/81 (Hill climb), 911/82 (Airport), 911/83 (Fast circuits) and 911/84 (Nurburgring ratios). One of these 911/8x would command a high price. If the number "12" appears between the type and transmission numbers, it was originally fitted with a ZF LSD. Angela, the 912 mounts were soft rubber and allowed a large degree of movement. There is a cast aluminum retainer over the rectangular rubber mount. This is to prevent the engine & transmission from falling out when the rubber fails. ![]() Best, Grady
