-   -   Source for a back up light conntector on a G50 tranny (http://forums.pelicanparts.com/porsche-911-technical-forum/443721-source-back-up-light-conntector-g50-tranny.html)
mthomas58 11-29-2008 11:06 AM
One of the two back up light pin connectors broke off on removal. Not sure if I'm going to salvage it or ruin it in the process. Anyone got a source for these rather unusual connectors?
UPDATE: found p/n 911-612-907-00 may be a special order item from Germany
http://forums.pelicanparts.com/uploa...1227988767.jpg
http://forums.pelicanparts.com/uploa...1227989071.jpg
john walker's workshop 11-29-2008 12:32 PM
drill it out and resolder or get one at the dealer. part # 911 612 907 00
911nut 11-29-2008 12:37 PM
+1 on the drill out/resolder.
I've had to do both connectors going to the switch on my car.
Dixie 11-30-2008 07:23 AM
I drilled mine out and soldered it back on.
A friend told me he simply used the male half of a crimp-on connector available at any parts store...
9dreizig 11-30-2008 07:42 AM
The problem is they are a little skinney so you'll either have to bend them a bit OR I've used a small bolt the same diameter as the "bullet" with nut on it and attach to a circle connector.
dean 11-30-2008 01:34 PM
That is what she said. Sorry Todd, couldn't resistSmileWavy
I would desolder and reuse
spuggy 11-30-2008 01:59 PM
The right tool for the job is a $5 desoldering pump, sometimes called a "solder sucker". Rat Shack carry them, along with 1000's of others.
Cock it, heat the connector with the soldering iron until the solder is molten, stick the teflon tip in the end of the bullet and press the button.
Job done, just resolder the connector.
This is also the way to get rid of/remake those nasty cold/dry joints the factory supplied in the 80's on just about every circuit board in the car (the dull-looking ones with all the flux not boiled off). I'm amazed any of those ever worked/still work/passed QA.
9dreizig 11-30-2008 04:17 PM
After she called you little and skinny, you'd desolder and re-use her??? You're more forgiving than me dude!!
BTW,, things only got better after I left you guys yesterday if you know what I mean hehehehe
