Throw it on the ground!
Source for a back up light conntector on a G50 tranny
One of the two back up light pin connectors broke off on removal. Not sure if I'm going to salvage it or ruin it in the process. Anyone got a source for these rather unusual connectors?
UPDATE: found p/n 911-612-907-00 may be a special order item from Germany ![]() ![]()
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 11-29-2008 at 11:40 AM.. |
drill it out and resolder or get one at the dealer. part # 911 612 907 00
Metal Guru
+1 on the drill out/resolder.
I've had to do both connectors going to the switch on my car.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Southern Class & Sass
I drilled mine out and soldered it back on.
A friend told me he simply used the male half of a crimp-on connector available at any parts store...
Dixie Bradenton, FL 2013 Camaro ZL1 |
The problem is they are a little skinney so you'll either have to bend them a bit OR I've used a small bolt the same diameter as the "bullet" with nut on it and attach to a circle connector.
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
That is what she said. Sorry Todd, couldn't resist
![]() I would desolder and reuse
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
The right tool for the job is a $5 desoldering pump, sometimes called a "solder sucker". Rat Shack carry them, along with 1000's of others.
Cock it, heat the connector with the soldering iron until the solder is molten, stick the teflon tip in the end of the bullet and press the button. Job done, just resolder the connector. This is also the way to get rid of/remake those nasty cold/dry joints the factory supplied in the 80's on just about every circuit board in the car (the dull-looking ones with all the flux not boiled off). I'm amazed any of those ever worked/still work/passed QA.
'77 S with '78 930 power and a few other things. |
BTW,, things only got better after I left you guys yesterday if you know what I mean hehehehe
