Poor-sche Lover's Avatar
What does this button do?
I'm still trying to get to know my '88 cabriolet. I don't have an owner's manual so I can't look at the diagrams. I have several switches and knobs that I don't quite know what they do. The top has been converted to manual, so I'm sure some of them are dummy switches by now. I have to know, though. From left to right, here's what I know.
1) This is a small black vertical knob with a silver face. It twists with a click, much like the intermittent wiper knob. I have no idea what it does.
2) This is a forward/backward black toggle switch. I entertain the possibility that it may be aftermarket. I have no idea what it does.
3) This is a forward/backward black rocker switch that still makes noise as I move it. I think this is supposed to control the cabriolet top. I'm just surprised it still tries to operate.
4) This is a left/right black rocker switch. This one I actually know. It operates the left/right mirrors. Again, I'm surprised that there seems to be no "neutral" position. To the right is the right mirror, and "flat" is the left mirror.
5) This one is the kicker. I didn't even know it was there until last week. It is similar to the toggle switch on 2). However, it is mounted in the rear corner of the glove box. Again, I would expect that this is aftermarket, but I can't figure out what it's for. I think the wires splice into the loom that goes into the radio. Has anybody heard of any switch like this?
Thanks,
Alan
Alan
Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again
Present: '00 Boxster S
"Happiness is not around the next corner......happiness IS the next corner."
Old 11-29-2008, 07:56 PM
crustychief's Avatar
There are no pictures.. so where are these knobs located?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 11-29-2008, 08:09 PM
Sorry, I probably should have mentioned that. 1) - 4) are all on the dash to the left of the steering wheel. 5) is self-explanatory.
I'll get a picture tomorrow.
Alan
Old 11-29-2008, 08:12 PM
3 sounds like the sunroof/cab top switch as mentioned, my car is a 79 and the owners manual is in the glove box at the body shop right now. Someone will post pretty soon though.
Old 11-29-2008, 08:17 PM
Here are the pictures...
Alan
Old 11-30-2008, 11:58 AM
sudo apt-get purge 930
equality72521's Avatar
The two left ones look aftermarket.
--clutch-monkey
Old 11-30-2008, 12:02 PM
Recreational User
porschenut's Avatar
The one in the glove box is aftermarket too. Crazy place to put a toggle switch.
Old 11-30-2008, 12:14 PM
That's what I figured. I just can't imagine what they're for. I keep hoping it's for hyperspeed or something cool like that.
Alan
Old 11-30-2008, 12:17 PM
steely's Avatar
I think only switches 1 thru 3 may be associated with hyper-speed or sub-warp, but you've mentioned no evidence of a flux-capacitor - what year did you say this was?
Seriously, I agree w/ you, your #4 is stock, and there is no neutral position.
Number 3 may be stock, since it coincides nicely with the indent on the panel.
You've definitely got some investigation to do.
I guess possibilities are extra lights, sound, or engine, batt, fuel relay cutoffs, but they're usually hidden (glove box candidate).
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 11-30-2008, 12:59 PM
DonMo's Avatar
Send a message via AIM to DonMo Send a message via Yahoo to DonMo
One is for the toggling of the outside mirror adjustments, the other I belive is for the headlight washer.
DonMo
1984 911 Carrera Targa
3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip
Columbia, SC
"Go Hokies"
Old 11-30-2008, 01:03 PM
#3 is for the automatic top. Where is the noise coming from when you press it?
#4 is for the outside mirror adjustment. Choose the side, right and left, and then use the control switch on the door panel.
The rest are aftermarket, and cheesy looking, so I would be suspect of what they do.
Bill
Old 11-30-2008, 01:17 PM
3 restos WIP = psycho
kenikh's Avatar
probably to an alarm...look for the controller box.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-30-2008, 02:21 PM
I probably will get rid of them eventually, but I'll have to find plugs to fill the holes for now. I have not tried to flip the glove box switch while it's running. i might do that. The car has the factory alarm, though it's not hooked up anymore. As far as looking for the controller box, there are so many unidentified boxes under there, that I can't tell what's factory and what isn't. We'll see what happens. By the way, I don't have headlight washers on my car.
Alan
Old 11-30-2008, 02:27 PM
Zeke's Avatar
Both the lever types are aftermarket as is the rotary. The rotary sounds as if it is a potentiometer with an off position. Perhaps it replaces the part of the headlight switch that controls the instruments. I'll bet the glove box one is some type of "hidden" kill switch.
Can you trace the wires? Any wire to switches like these will probably not be in the factory harness, but could be wrapped to look like one. Usually you can tell a bogus wire on the fuse panel. Few dew that as well as the factory.
Old 11-30-2008, 03:05 PM
