Porsche-pa
75Carrera's Avatar
Three questions for experienced Pelicans
1. I've always heard it would be far worse to "overfill" your car with oil than to run it several quarts low.
Q. WHAT EXACTLY HAPPENS TO THE MOTOR IF IT'S OVERFILLED AND DRIVEN?
2. Spark plugs come pre-set and are installed to a tight fit.
Q. IS IT NECESSARY TO TORQUE A SPARK PLUG INTO PLACE?
Q. IF SO, WHAT WOULD HAPPEN OF THE SPARK PLUG IS NOT INSTALLED PROPERLY?
My motor's on the floor. Your experience would help clear up some diagnostic issues I'm trying to figure out with this motor. Thanks...
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 10-31-2008, 03:52 PM
RETIRED
Joe Bob's Avatar
Over filling allows oil to be sucked into the intake.......you then have no mosquitos for 6 city blocks.
I always gap a plug.....
I tighten plugs but not overly so.....
2012 ML350 3.0 Turbo Diesel
Old 10-31-2008, 04:01 PM
abit off center
cgarr's Avatar
"Stop. Who would cross the Bridge of Death must answer me these questions three, ere the other side he see"
______________________
Craig
G2Performance
Old 10-31-2008, 04:47 PM
Formerly known as Syzygy
Canada Kev's Avatar
What is the maximum velocity of an unladen swallow?
Kevin
Old 10-31-2008, 04:59 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
European or african?
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 10-31-2008, 05:00 PM
SCOTITUDE's Avatar
But seriously,
Overfilled , the car will smoke like James Bond's. Thick white smoke, a lot!
The plugs should be snug.
2008 E93 M3 DD
Old 10-31-2008, 05:08 PM
moneymanager's Avatar
We are not taking this man's intelligent questions seriously.
Let he who would ride backwards on the wing of a sparrow experience the joys of overfilling.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-31-2008, 08:53 PM
HarryD's Avatar
On a serious note:
1-Your car will smoke profusely and the vchciks will not longer dig you.
2-You do not need to torque them, just get them snug.
3-If they are loose, they fall out and you lose power and hear this funny sound.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 10-31-2008, 09:06 PM
SteveinTO's Avatar
Not to be contrarian, but:
1) I'd rather deal with the mess and a lot of smoke than a dry bearing.
2) Gap your plugs, it's easy & you sleep better.
3) Use a torque wrench, they're cheap (beam type) & the process is easy. The "just snug" scenario leaves one open to the "just a little more snug" must be just a little bit more better. Until you go "over-snug."
I feel better. Thank you!
Old 10-31-2008, 09:16 PM
Canada Kev's Avatar
Overfilling will generally push the excess oil in through the breather or the PCV to the intake where it will be very obviously burned in the engine. Lots of white smoke and pissed off other drivers and neighbors. As well, too much oil pressure can sometimes damage engine seals and such.
I can't see a couple quarts low as being an issue. Note that the engine is cooled by oil and that having less may cause an issue with temperatures as there will be less to dissipate the heat.
I am assuming by "pre-set" you mean the gap. It is a good idea to double check, and correct if needs be, the gap of any new plugs.
Sorry, I don't know. Normally I don't use a torque wrench when changing plugs, but I honestly don't know if you should.
Perhaps you could clarify what you mean by "not installed properly". If you cross thread the plug, not good things may happen. Other than buggering up your threads in the head, the plugs may not thread all the way in, not seat properly and leak under pressure, or just loosen when at an inconvenient time. There may be other issues, too.
Hope this helps. I hope you don't take offense to the Monty Python references and general goofing off. I couldn't help myself. Must be the Halloween air or maybe just too much candy...
-kevin
Kevin
Old 10-31-2008, 09:22 PM
HarryD's Avatar
I should add that since I use the factory tool (from the car's tool kit) to remove/install the plugs, it is difficult to use a torque wrench in this location. YMMV.
Harry
2020 MB E350 4Matic
Old 10-31-2008, 09:50 PM
AutoBahned
RWebb's Avatar
despite the movie and its argument, this is known to be at least 14 m/s. Park, Rosén, and Hedenström. 2001. Flight kinematics of the barn swallow (Hirundo rustica) over a wide range of speeds in a wind tunnel. J. Exp. Biol. 204: 2741-2750.
in contrast, a "surging" glacier moves about 0.000007 m/s
which is much faster tha growing fingernail
[the latter being close to the slip seed of the N. Am. tectonic plate]
-- no charge for edifying you
Old 10-31-2008, 10:03 PM
Canada Kev's Avatar
Christ, I hope so. That would be like having fingernails 7 cm long in a week. That's almost three inches. Man those glaciers really rocket down the slopes.
Kevin
Old 10-31-2008, 11:05 PM
Wer bremst verliert
JohnJL's Avatar
Torque is around 20 ft/lbs.
If you undertighten they will work loose and eventually make a "BANG" and rocket one across the floor (if its a bottom plug.) I can attest to this.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-31-2008, 11:29 PM
Bill Douglas's Avatar
75 911 Carrera Sunroof Coupe #215 Guards (arrest me) Red all black trim, 7&8 Fuchs, lowered, fresh 3.2, Forged 10.5x1 pistons, Ollie's heads/valves, John Doughtery 964 cams, test pipe (no cat) two out modified exhaust, customized Steve Wong chip, alloy Carrera brakes, new Koni's and poly bushings, TOYO T1R's, Bose sound w/ 4-6x9 and 4-5" Bose, 915 with Porsche factory short shift
(owned for 27 years)
Prescott, Arizona
A few of my "Also Rans"...
76 911S
68 912
85 930
Donny, you are an experianced Pelican,
Old 10-31-2008, 11:59 PM
grateful user
don gilbert's Avatar
plugs
not only should they be gapped, i like to index my plugs toward the intake valves, not hard to do, make a line with a sharpy all the way up the socket and extension.
Old 11-01-2008, 06:59 AM
Non Compos Mentis
I've always indexed my plugs so that they face Germany.
Old 11-01-2008, 07:08 AM
SCOTITUDE's Avatar
That is classic. A huge belly laugh on that one. Made my mornin.
2008 E93 M3 DD
Old 11-01-2008, 07:40 AM
------- oil in the tank is at a higher level and it's easier for it to vent into your intake air chamber.
------ many guys reset gap. If you're using stock ignition confirm stock suggested gap.
-------- it depends.
The un-experienced may want to try a torque wrench to learn a "feel" for how tight it should be. Spark plugs like ours use a gasket and the idea is to just compress the new gasket for proper torque. A common routine is to twist the new plug and gasket 1/4 turn after it initially bottoms.
------- over tighten and you have steel plug threads twisting aluminum threads. On steel heads over tighten may disturb plug gap.
plug threads never seize is another issue which seems to bring out a few personal preferences
meanwhile it's better to ask more basic questions to bring out some humor around here
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-01-2008, 08:07 AM
Sultan of Sawzall
rouxroux's Avatar
It all depends......"What is your favorite color"?
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 11-01-2008, 08:10 AM
