safe's Avatar
Worn valve guides?
3 of my exhaust ports look like this, the other 3 are dry, clean and nice.
Due for a top end rebuild?
And yes, it smokes a bit...
Magnus
Old 12-01-2008, 01:38 AM
old man neri's Avatar
What is your oil consumption like?
Old 12-01-2008, 02:50 AM
safe's Avatar
I don't keep record of it. On the 2500 miles (~300 at the track) I put on it this summer, 4-5 quarts at least maybe up to 8.
After a track day I may have to top it up a quart or more, but on the street a quart goes a long way.
Magnus
Old 12-01-2008, 02:59 AM
8 quarts in 2500mi? That's something like 315mi/quart. That's pretty high from what I have heard.
Old 12-01-2008, 03:36 AM
What's the mileage and history of your car, Magnus? Has the engine been apart before? Lots of possible while-you're-in-theres with a '77.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 12-01-2008, 04:17 AM
safe's Avatar
112-113.000 miles, never been apart, aside from chains and tensioners. I have talked to most POs. Before me the car has probably had a pretty relaxed life.
Magnus
Old 12-01-2008, 04:24 AM
113,000 miles was far enough for my 2.7.
If you also need rings it may be a good time to split the case or just get another engine.
I rebuilt and made sure to have the case line bored by a Porsche experienced machinist.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-01-2008, 04:34 AM
Bollweevil
When I had my 2.7 rebuilt at 90K miles, the valve guides were in such bad shape we had to replace all 6 exhaust valves. Note: Many of the 90K miles were put on the car in S. Texas (very hot climate) and the car had no external oil cooler.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 12-01-2008, 04:58 AM
MBruns for President
JeremyD's Avatar
Similiar to what mine looked like before I started my top end. I'd start monitoring your oil consumption. When it gets (or if it is) around 300-400 miles per qt - time to dig in.
Old 12-01-2008, 05:11 AM
safe's Avatar
I have another engine ready (well, soon) to go in. I might need the old engine once every second year for inspection so I'm keeping it and I was entertaining the thought of rebuilding just the heads for fun. But I wont be putting a lot of miles on so I might just leave it as is.
Magnus
Old 12-01-2008, 05:13 AM
If I was looking for a cheap way to buy some miles I'd just replace the exhaust valve seals.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-01-2008, 06:17 AM
84toy's Avatar
The short answer.....Yes. If oil is pouring out of the guides that bad, the seals and/or guides are wiped out. Can you still drive it?....sure. However I suspect the guide has significant wear and the valve slopping around in a large hole invites extreme valve seat wear and possible valve breakage.
I recently pulled an engine down that had .014" wear in the guides vs the appropriate .002. The oil in the port was less than yours and it didn't use that much oil. When finished, the engine was much quieter.....pic for you
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 12-01-2008, 06:46 AM
abit off center
cgarr's Avatar
If you let it go too long your seats can get beat so out of round that they may not be able to cut them round again.
______________________
Craig
G2Performance
Old 12-01-2008, 07:46 AM
Friend of Warren
Or this can happen, like on my 3.2 with worn valve guides:
Kurt V
Old 12-01-2008, 08:03 AM
safe's Avatar
I have known for a while that they probably been a little worn... It has problem holding the valve adjustment, it gets noisy quite quick. Not sure if that's related.
Maybe I just change the seals and baby it, if everything goes to plan it will only be used 10-15 miles every second year.
That's nasty Kurt!
I keep being surprised how well these engines run despite all kind of wear and tear.
Magnus
Old 12-01-2008, 08:12 AM
durn for'ner
livi's Avatar
Fingers crossed, Magnus.
Markus
Resident Fluffer
Carrera '85
Old 12-01-2008, 09:33 AM
Recreational User
porschenut's Avatar
Yeah, it's related for sure. Valves not staying adjusted is one of the tell-tale signs of worn-out valve guides.
Old 12-01-2008, 10:41 AM
I can't wait to measure my wear - I hope to hold the world record for most worn (but still intact) 911 valve-guides very soon.
This seems like an appropriate place to ask - Does anyone know any specifics I could ask my local machine shop (or anything that makes installing guides in these heads different from any other aluminum head)? I've used them for years for domestic stuff and they build a lot of race motors but I suspect their Porsche experience is limited. Still, I can't imagine they aren't up to this task unless someone can offer some information to the contrary.
1989 Carrera 3.2L in 993 bodywork
Old 12-01-2008, 03:17 PM
I've been told my valve guides are wearing out which is causing some noise. The valves were adjusted about 5k miles ago. The valve seats getting beat out of round has me wondering how long I can go before a top end job. My oil consumption is very good. At least 1 quart per 1K miles and maybe even a bit more. Which is going to come first....physical damage or higher oil consumption?
1987 911 Carrera
2006 Audi A3
Old 12-01-2008, 06:14 PM
I'm not a P machinist but I do know that you just can't just slam them in. May be same routine for other manufacture Al heads but I don't know. It's been discussed here very rarely. I'd find out exactly how to do them before proceeding.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-01-2008, 07:08 PM
