Transmission cooling wisdom
Several months ago I tracked my stock '79 SC for about 1.5 hours with small breaks every half hour. The engine stayed cool, the breaks overheated some, but it seems that the transmission overheated quite a bit - since then my speedometer has been showing half the actual speed and I assume that has to do with the tranny overheating.
I now have an external front-mounted cooler on the engine, plan to duct my brakes, and am considering whether I should install a transmission cooler to make this a trouble-free track machine. Currently I am planning to continue using it for events, not for racing.
My question is: In my situation, does it make sense to go through the troubles/expense of installing an oil cooler? What are the costs, how difficult of a job is it, does it increase maintenance or affect usability of the car, and does the kind of use that I put the car through merit transmission cooling? I'd also appreciate comments on the different systems/what is best, and where to get them.
By the way, the tranny is out of the car due to an engine rebuild and I am contemplating a tranny rebuild.
Many thanks for reading.
Old 12-03-2008, 12:05 AM
Hi,
First, I must tell you that I've RARELY seen an overheated 915 coupled to a stock 3.0 engine since they do not produce enough torque to place excessive loads on it. I would ask you what oil have you been using in your transmission and was it filled to proper capacity?
If you really do need a cooler, I'd kindly suggest that you install AN-8 fittings in the transmission and plumb a Tilton pump with a Setrab cooler to do the job properly. Mount the cooler under the engine grille on left side.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-03-2008, 12:37 AM
Max Sluiter
Flieger's Avatar
How did you know the transmission was overheating?
Old 12-03-2008, 01:55 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I bet you your speedo also only shows half the distance traveled now. Sounds like you lost some of the magnets that trigger the speedo sensor. There should be 8 pulses for 8 magnets for every full wheel rotation.
And as Steve said, it sounds unlikely that you overheated the transmission with a stock 3 liter by 30 minutes of track driving unless somehting was awefully wrong with it (oil level or quality)
As a single data point I sometimes track my Targa with a Magnesium 7:31 915 with a 3.6 and it doesn't overheat. Does it get hot, you bet. Would a cooler make sense, you bet. But I put 30,000 happy miles through that tranny so far without any issues. The only mods I have are a single-piece bearing retainer and a reinforced differential cover plate. And I don't drag-race it unless I have to beat MikeZ
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 12-03-2008, 03:14 PM
GrantG's Avatar
This kit from WEVO has been working nicely for me. Before installing, the shifting would be far less smooth (difficult to select certain gears) on hot days and long run sessions on the track:
http://wevo.com/Products/TransmissionProducts/WevoTransmissionProducts-Cooling.htm
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 12-03-2008, 03:18 PM
RETIRED
Joe Bob's Avatar
Ingo
Drag racing???? Never happened, you DID beat me by .1 second in an Autocross, but every one knows that ain't racing.....
2012 ML350 3.0 Turbo Diesel
Old 12-03-2008, 05:39 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Steve, just for fun what type of gear oil do you recommend? Hot rodded and mildly warmed over street cars that get checked but not changed all the time driving in nice weather and arent pushed very hard until they are warm would probably be the type that most all here would fall into the category of. I know a lot of people love Swepco 201, I have used it along with Redline lightweight and heavyweight shockproof as well as some Lucas and Mobil 1 synthetic products.
So could you share with us your preference...
74 911s neverending story. two feet and a jetta for now.
Old 12-03-2008, 08:12 PM
ischmitz's Avatar
I think the consensus is that the 915 fares best with a dyno product due to its synchro design. And most use Swepco 201 so why experiment. Change is annually and you are fine.
Old 12-03-2008, 09:08 PM
Swepco 201 (sometimes # 210) only for these transmissions (901-915-930),....
Using synthetics in a baulk-ring syncromesh gearbox REALLY accelerates wear on brake bands, operating sleeves, and dog rings, even though it might shift OK for awhile. Check the price of 915 parts and the folly of using synthetics will become painfully obvious.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-04-2008, 12:56 AM
