Question Throw Out Bearing Guide Tube
Is there a specification for the throw out bearing guide tube outer diameter?
When I put the TO bearing on the tube it has a very small amount of play, is this acceptable?
86 911 carrera
86 911 coupe
2001 VW TDI
Old 03-11-2005, 12:44 PM
abit off center
cgarr's Avatar
I just had mine out! I only had two small ware spots that I welded up and turned back down on my lathe, Mine has very little play, thats why I fixed the spots, thinking to slide well it had to fit close otherwise it looked like the bearing could get cocked if there was too much play.
Craig
______________________
Craig
G2Performance
Old 03-11-2005, 01:36 PM
Is there any way to check a guide tube? Mine "looks" fine on my '88 which had a new clutch put in by the PO just before I bought it and I believe this was replaced.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-02-2008, 10:52 AM
