Schredder
Question Lumpy idal 3.2
I have a 89 3.2 Carrera that has a rough idal at 800rpm. It sings like a Porsche should at 2000rpm. Any ideas ? A dirty throttle body ? It has 62k and I did all the required maintnence at 60k about a year ago.
One more......... When it is cold it feels like it is pulsing, like it needs fuel. I put in a new fuel filter but under load I still feel the pulse.
Old 12-02-2008, 11:39 PM
Welcome aboard Rick...nice car ! Use the search feature above, to search the 911 forum only with "hunting idle", "idle control valve" (ICV), etc. and you'll find lots of threads and tips in the archives. You'll want to check your ICV, possible vacuum leaks, etc. to track it down. BTDT, and my idle is perfect now...good luck!
Old 12-03-2008, 03:19 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
+ 1 on the ICV....remove-clean-re-install....if the problem still there, buy a can of ether and spray it gently over the vaccum lines...any leak will cause a surge in RPM....Ho...very nice 911....and welcome aboard.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 12-03-2008, 04:10 AM
I'm with Bill
Rick V's Avatar
Welcome aboard. The above suggestions are a very good place to start.
I just gotta jump in here and go wow.
1 Name: Rick
2 car: same color
3 Wheels: same.
too weird
Welcome to the forum.
Old 12-03-2008, 04:39 AM
old man neri's Avatar
When was the last tune up? Plugs, cap, rotor, valves, possibly ignition wires...etc. These may explain a rough idle, not a hunting one.
Old 12-03-2008, 05:31 AM
Schredder
Thanks for the fast reply. I think i will look around for the ICV and clean it out.
I did the plugs , cap & rotor, wires ( the wires were breaking off stuck to the plugs ) last year.
Old 12-03-2008, 06:39 AM
I left my Oil cap off once and the idle seems rough for some reasion.
Old 12-03-2008, 08:18 AM
