-   -   How did you attach your rubber hood/trunk latches? (http://forums.pelicanparts.com/porsche-911-technical-forum/444609-how-did-you-attach-your-rubber-hood-trunk-latches.html)
Rich Lambert 12-04-2008 12:32 PM
The title says it all. After searching 3 different forums, I've seen rivets and drill, tap, and glue in a screw.
Did you trust your attachment method enough to remove the secondary catch on the hood? I had hood pins on my 912 vintage race car and got stopped once by an alert pit worker who noticed I forgot to put the clips back in. That would've sucked as I did trust them enough to remove the secondary catch.
obrut 12-04-2008 03:58 PM
rivets. no problems - including a 4 day rally with numerous jumps/air.
Zeke 12-04-2008 04:05 PM
I used sheet metal screws into any blind area and machine screws/nuts/washers in accessible areas.
911ctS 12-04-2008 05:01 PM
+1 on what Milt said.
I used machine screws on the rear "R" hinges for the duck tail and sheet metal screws for the rubber hold downs into both fiberglass pieces (duck and bumper). For the front I would lean a bit more towards the machine screws and nuts since you should be able to get to the area under the lop ledge of the bumper fairly easily.
mede8er 12-05-2008 03:02 AM
+2...and put that secondary catch back in!!!
haasad 12-05-2008 03:37 AM
Hi I used rivnuts (available in steel or aluminium) for all surface mounted features on my r car . They are available countersunk or flanged .
andy
rfn026 12-05-2008 03:40 AM
Rivnuts are the way to go. I love them.
Richard Newton
Autocross Performance Handbook
Mr9146 12-05-2008 02:46 PM
Couple of things:
1) I used sheet metal screws or nuts/bolts/washers (depending on location) on all of the rubber hold downs I've installed. I've had no problems.
2) On my personal car I did only the rear lid (which was fiberglass) and did not use a secondary latch
3) If you choose to remove the secondary latch it's probably a good idea to take out the hood shocks ... at least that way the hood won't "want" to go up.
SmileWavy
Rich Lambert 12-05-2008 03:31 PM
Could someone post some pics of "RIVNUTS" installed? It's hard to tell exactly what's going on from the website.
TimT 12-05-2008 05:03 PM
Rivnuts install similar to pop rivets the exception is they are threaded to receive a bolt..
You need a tool to install them... I've used a collar of suitable dia, and a high strength hex head screw to set the rivnut
here is a graphic soln
http://ourworld.compuserve.com/homepages/oakwood_data/pulling_rivnuts.htm
Rich Lambert 12-05-2008 06:23 PM
Thanks for the link Tim...thanks everybody for the replies!
I went ahead and used rivets, but I think I'll order some RIVNUTS, drill out the pop rivets, and replace 'em.
I like the look. I used Randy's great pics of Chris' car in Excellence #158 as a guide for placing the latches on mine. And I did leave the secondary catch on the hood.
http://granitehead.smugmug.com/photo...82_JCGJN-L.jpg
Ignore the drips...
http://granitehead.smugmug.com/photo...77_keWHB-L.jpg
cnielsen 12-05-2008 10:57 PM
Looks good Rich!
Debating on whether or not to do them on my '67...
Not sure I am a good model to follow though on latch placement...I just riveted them on where I thought they looked good!
911pcars 12-05-2008 11:33 PM
This might be obvious, but I suggest using rubber latches that only have stainless steel hardware (mounting plates and fasteners). Plated steel will eventually .... rust along with anything steel in contact with it.
Sherwood
Rich Lambert 12-06-2008 08:29 AM
Originally Posted by cnielsen (Post 4343557)
Looks good Rich!
Works for me.
dicklague 04-11-2011 07:16 PM
Sherwood
Good Point! I agree.
