"farking Porsche hero"
How did you attach your rubber hood/trunk latches?
The title says it all. After searching 3 different forums, I've seen rivets and drill, tap, and glue in a screw.
Did you trust your attachment method enough to remove the secondary catch on the hood? I had hood pins on my 912 vintage race car and got stopped once by an alert pit worker who noticed I forgot to put the clips back in. That would've sucked as I did trust them enough to remove the secondary catch.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
rivets. no problems - including a 4 day rally with numerous jumps/air.
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
I used sheet metal screws into any blind area and machine screws/nuts/washers in accessible areas.
+1 on what Milt said.
I used machine screws on the rear "R" hinges for the duck tail and sheet metal screws for the rubber hold downs into both fiberglass pieces (duck and bumper). For the front I would lean a bit more towards the machine screws and nuts since you should be able to get to the area under the lop ledge of the bumper fairly easily.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
Porsche Junky
1986 930 RUF equipped |
Hi I used rivnuts (available in steel or aluminium) for all surface mounted features on my r car . They are available countersunk or flanged .
andy |
Couple of things:
1) I used sheet metal screws or nuts/bolts/washers (depending on location) on all of the rubber hold downs I've installed. I've had no problems. 2) On my personal car I did only the rear lid (which was fiberglass) and did not use a secondary latch 3) If you choose to remove the secondary latch it's probably a good idea to take out the hood shocks ... at least that way the hood won't "want" to go up.
Could someone post some pics of "RIVNUTS" installed? It's hard to tell exactly what's going on from the website.
Navin Johnson
Rivnuts install similar to pop rivets the exception is they are threaded to receive a bolt..
You need a tool to install them... I've used a collar of suitable dia, and a high strength hex head screw to set the rivnut here is a graphic soln http://ourworld.compuserve.com/homepages/oakwood_data/pulling_rivnuts.htm
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 12-05-2008 at 05:30 PM.. |
Thanks for the link Tim...thanks everybody for the replies!
I went ahead and used rivets, but I think I'll order some RIVNUTS, drill out the pop rivets, and replace 'em. I like the look. I used Randy's great pics of Chris' car in Excellence #158 as a guide for placing the latches on mine. And I did leave the secondary catch on the hood. ![]() Ignore the drips...
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" Last edited by Rich Lambert; 12-05-2008 at 06:25 PM.. |
Looks good Rich!
Debating on whether or not to do them on my '67... Not sure I am a good model to follow though on latch placement...I just riveted them on where I thought they looked good!
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
This might be obvious, but I suggest using rubber latches that only have stainless steel hardware (mounting plates and fasteners). Plated steel will eventually .... rust along with anything steel in contact with it.
Sherwood |
Works for me.
Good Point! I agree.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
