zugelassener benutzer
To remove A/C or not?
I'm new to the forum and have an '86 Carrera Coupe with factory AC that does not currently function and that I would not use if it did. Beyond the obvious benefits of removal (weight, power, simplier) would it hurt resale value if it had non-functioning AC on the car vs. removed in a box. It's a clean 78K car that I am going to use everyday for a while and eventually buy another everyday car. I will periodically Auto-X and track it.
Resale matters because I really wanted, and will end up with, an '87-89 or long nose car, or likely a conversion project, but this one was too nice to pass up. ![]()
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing 7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo 32C #7 |
My opinion only. Since you are indeed going to sell the car in the (apparently) near future, I'd keep the AC installed. The weight will affect your track times (I presume) but the hp drag will not because the clutch is not engaging the compressor. If you want to be safe, just remove the belt to the compressor. To reach a happy compromise, you may wish to just remove the compressor and evaporator from the engine compartment--save weight and they are easy to reinstall before you decide to sell.
I think having a factory AC helps in resale, even if it doesn't work. Keep as many doors open to potential buyers as possible and fixing an AC is much cheaper and easier than reinstalling the components. BTW, your car looks truly great. I can see why you just couldn't pass it up.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
THE IRONMAN
+ 1...if you plan to sell the car...keep it installed.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Removed in a box AC = no AC at all for resale purposes.
+1
Wow- nice looking car!
84 911 Targa (Goldie) 72 914 1.7+ (Greenie) |
Recreational User
It depends on why it's not functioning. If it can be fixed just by replacing a component such as the compressor or clutch, then it's obviously worth more on the car than in a box.
The key is how much money it's going to cost the next owner to get the A/C working. If it costs more to reinstall the parts, leave it in the car. If it will cost the same or more to get it working (e.g., replacing all the hoses is a lot of labor), then it shouldn't make much difference. I say leave it in the car just to be safe. The next owner will prefer it that way. A big deal is made on these boards about reducing weight. Will knocking 1 second off of your lap time be worth the hassle and probable loss of resale value? My advice is just have fun on the track and forget about lap times. 60 lbs. isn't going to make any difference in how the car feels. If you want to save 60 lbs., remove 7 gallons of gas from your tank. |
black car no ac = hot car
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Your car is a beauty. I'm thinking about the same thing for my 77 911S but I think I will remove the compressor so I have more room in the engine bay. If/when I sell this car it's in the box in the trunk if they want it.
'82 SC TL
Ohhhh, keep that sweet car looking they way it does, real sweet, don't remove the "working a/c"!!!! my opinon, if I was shopping around for a 911 like that one, I would pay extra for "working a/c", just my opinion
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Yes, very nice looking Carrera. I would DEFINITELY keep the A/C in there.
Mike |
Zuffi-Freund
Nice car! Don't forget to list here when you want to sell
![]() best regards Heiko |
Nothing like a black Carrera. Great looking car.
++1 on keeping compressor in a box, and leave everything else in place.
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
The current economic conditions will have more of a negative impact on the resale than removing the A/C, in my opinion.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
So, I guess the conclusion is keep the AC, but remove the current economic conditions.
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
It would only save you about 45 lbs.
86 is a great car. It has uprated rear springs and biger ft and rr sway bars. The seat is lowered for more head room. And, it weighs 100lbs less than a 87-89 G50. Keep the 915 car. Take the spare, jack, compressor out of the trunk and fit a light weight battery for 100 lb savings. Slip a cat bypass or pre muffler in it, sport muffler, and SW chip for a 2700 v 2900 lb car and about 230-250hp. If you are going to turbo a car, get a G50. |
Excellent point on the weight. There is less weight to a 84-89 A/C system than with the SCs systems. I weighed all components from my system at it was about 80lbs.
