Nice car!
I just removed the compressor from my '87. Yes, it's not a lot of weight but it's hung pretty rearward and the removal makes the engine compartment look better and more focused. Reinstall is easy and I think can be done in less than 30 minutes if you are selling the car someday
'87 3.2 Targa
Old 12-07-2008, 05:30 AM
zugelassener benutzer
teamfee3's Avatar
This forum is incredible, I hope I can make a decent contribution one day. I am going to keep the A/C in, remove the compressor but leave the mount. It looses some weight, cleans up the engine bay and looks like a clean job in and out. If the A/C could be put back in action easily I might do that but I would never use it and life tells me if something isn't used it generally stops working at some ppoint anyway.
I also like some of the other suggestions. I'll post a before after once the motor is back in - also deciding on engine fan, currently gloss black housing with silver fan but might change it.
This is it as I bought - more to come....
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 12-07-2008, 08:26 AM
NO LIFT's Avatar
I'm in the same predicament. A/C I that doesn't work, and I haven't fixed it anyway. Thanks for the great advice from all.
But, what do I do with the open hose ends after I remove my compressor and evap from the engine compartment?
Guidance would be appreciated!
Old 12-07-2008, 08:54 AM
This is what I did a few years back:
Gratuitous pics of Carrera heater backdate...
Old 12-07-2008, 11:01 AM
I took some PE wrap from the kitchen to wrap the the open hose end and just displace the hose to under the oil filter.
I didn't remove the evap because my turbo tail was off and I need the evap to work as grill for now Any one has a spare engine lid grill for sale?
'87 3.2 Targa
Old 12-07-2008, 05:27 PM
Hmmm...my AC is in a box, and the economy is in a coffin. Coincidence, or should I immediately reinstall my AC as my patriotic duty to help the country recover?
So your are the culprit
Dang man, put that A/C back in and go buy bunch of stock! We are all counting on YOU.
Old 12-07-2008, 06:52 PM
