-   -   R / Outlaw project... (http://forums.pelicanparts.com/porsche-911-technical-forum/445103-r-outlaw-project.html)
carrerarsr65 11-04-2015 12:09 PM
woops lotsa great roads
bugstrider 11-04-2015 02:13 PM
Originally Posted by jury (Post 8863225)
Had a busy couple of weeks, but there is an update.
I have now got Licence plates for the car! It was really straight forward. I showed up at the DMV, got my numbered ticket and waited inline with the varied and socially interesting folk this city seems to attract. The guy behind the counter did his best to make me feel like a school child called into the head masters office but I gradually broke him down. Then, all of a sudden, he asked me which plates I would like..."Vintage re-issue please" and that was that. I could have kissed him, I offered a hug, but we settled on an awkward handshake. I wanted to explain what this moment actually meant to me, but quickly realised that the story would be lost on.....he called the next number, I left.
Anyway, plates and paperwork...
That is probably the funniest DMV encounter write-up I have read in a long time. Needless to say I now have to clean the soda off on my desk at work because of the spontaneous blurt of laughter I belted out reading this.
Here in CA, our DMV encounters go about the same way. And I even have a backdoor knowledge of how they operate. I now fully can relate to the furry people experience. I was successful in getting 2 68 912's and my dad's 27 Model-T reregistered with period correct plates.
Good job on getting vintage plates and great write-up.
Cheers
Bugs
fanaudical 11-04-2015 09:05 PM
Congrats on successfully navigating the perils of the Oregon DMV. (My journey was much more difficult than yours, and I just brought in a car with a lost title from Washington...)
jury 11-05-2015 09:16 AM
Thanks for the kind comments, much appreciated.
Went for a longer drive yesterday, covered about 40 miles which included going to the local petrol station which sells Ethanol free ''Gas'' . Had an interestesting discussion with the attendant who was amazed that the engine was in the back, with this in mind I asked if he would mind if I pumped the Gas, he didn't mind and 10 gallons later I was ready to roll.
I had set the MSD rev limiter to 3000 just to make sure I wasn't going to damage anything during these first few hundred miles. First thing I found was that the 3000 limit doesn't make make for a smooth change from 1st to 2nd, and the previously mentioned heavy clutch doesn't help either. Once rolling all was good and I managed to get all the way up to 4th :rolleyes: . The ride is firm but very direct compared to the 912, but I haven't got anywhere near to feeling the balance and poise...one step at a time!
I made some running adjustments to the pedals and got alittle better suited setup, and also shifted the seat runners back to get a better driving position (still needs to be lower).
But the best thing is the sound !! Got some pops on downshifts which sounded cool :)
It is loud inside and outside, and is another candidate for the Loud Pipes Save Lives campaign...people certainly hear me coming. For the next trip out I am definitely removing the rear tool box and window straps, also probably the passenger harness...there is so much going on that it is impossible to tell if something is loose or just vibrating. I may need to find a passenger to identify what is what.
Got back home and had alook around, nothing leaking and Oil level 3/4 on the dip stick and at 180 degrees. Then just had to listen to the Idle.....we are all geeks :)
VIDEO
https://vimeo.com/144687208
VIDEO
https://vimeo.com/144687207
Set at 3000 rev-limit
Same again today, if the weather holds up.
Chris
kenikh 11-05-2015 09:21 AM
FWIW, I don't ascribe to the 3K rpm break in mantra. My 930 has about 600 miles on it, regularly see 5K rpm, and occasionally sees the 6.8k redline. Boost is still limited to .5 BAR though. I don't believe you should drive it like you hate it, but getting things spinning isn't the devil folks make it to be. 3 separate builds later, and tens of thousands of miles later, no regrets.
Bird911 11-05-2015 11:05 AM
I work for Harley-Davidson (in a previous life !) and we used to recommend to the new owner to keep the RPM under 3000 for the first 50mi and then under 3500 until 500mi. But most importantly, HD recommend to vary and not to keep a steady RPM for extended period of time.
I hope I'm correct on this, but if I recall, their theory was that the piston's rings were setting in on a longer portion of the cylinder wall, because the ignition timing was changing depending on the RPM. The spark occurring when the ring is a slightly different place in the cylinder.
I think it made sense, but it's just my opinion and you are allowed to disagree !
Amazing build BTW Chris. Congrats !
kenikh 11-05-2015 11:51 AM
FWIW, we used Gibbs BR break in oil. After doing the stationary camshaft break-in cycle, we ran the car at a 4K RPM limit for 25 miles, constantly varying the RPM. Once the drive was finished, we confirmed compression/leak had achieved the ideal for a fully broken in motor within that 25 miles. Not bad.
fanaudical 11-05-2015 06:54 PM
Sounds awesome! I do think a 3k rev limit may be a bit low - you don't want to lug that motor.
fanaudical 01-02-2016 04:25 PM
I had an opportunity to see this 911 in person today at PDX's Cars & Coffee meet. There isn't one frivolous piece of anything on this car; every component serves a distinct purpose. There is no end of elegant mechanical details to behold when studying this thing. If you ever get a chance to meet Chris and look at this car, take it.
jury 01-03-2016 08:54 PM
Nice to meet you over the weekend Jim...I have just about regained feeling again in my hands and feet.....it was FFFFFFFFFLIPPING FREEZING !!! Look forward to the next meet up, it was a nice little Porsche gathering
Cheers
Chris
kent olsen 01-04-2016 02:36 PM
You could start an interesting debate about engine break-in techniques. I've rebuilt two small block chevy's. I was told on both to not hold a steady rpm and if I remember, low rpm for a 100 miles and then up to a higher rpm for another and that was about it.
When I built the 3.0L in my Porsche I built it to safely turn 8000 rpm but with max power at 7200. The race shop in Florida that helped me, put the engine on an engine dyno for break-in and tuning. In two days we did 32 pulls to 7500 rpm. When I asked Mike about break-in after I put the engine back in the car he laughed and said "no it's ready to go now"!
jury 01-05-2016 08:03 AM
Will "up" it on the next run out...it certainly wants to Rev. If it breaks I'll fix it :)
New Years eve...
http://i161.photobucket.com/albums/t...psgzywcrvz.jpg
New Years day...
http://i161.photobucket.com/albums/t...psnygmpc2o.jpg
http://i161.photobucket.com/albums/t...pswp96cgcx.jpg
http://i161.photobucket.com/albums/t...psetac6pq2.jpg
http://i161.photobucket.com/albums/t...ps6k1p0omn.jpg
http://i161.photobucket.com/albums/t...pstjifje5g.jpg
http://i161.photobucket.com/albums/t...psugwcibor.jpg
"Not here for a long time, just here for a good time"
wachuko 01-05-2016 08:55 AM
Wow... just wow!
Facey 01-05-2016 10:35 AM
what a beautiful car.
carwash 03-13-2016 07:16 AM
I had to bump this to the top. This has been a wonderful book to read. Thanks Jury for the great times. I pm'd you.
I am curious if you did a full rewire of the vehicle. All of your wiring looks brand new. I am gutting my current car of all wiring and wondering if you started with a pre-made harness or build everything yourself.
matt930s 09-05-2016 03:50 PM
Great read. Any updates?
MattR
jury 12-04-2016 05:46 PM
So its been awhile...afew updates in no particular order ;)
Firstly, I love it ! Everything I hoped it would be...with so much more potential to come. However the main buzz currently is being able to drive it ( and the 912) year round, no salt, no winter tyre season etc etc.
Found afew nice routes and got acouple of all day runs in the planning.....along with some video planned.
http://i161.photobucket.com/albums/t...psqg04vcoy.jpg
http://i161.photobucket.com/albums/t...ps6i5cklp5.jpg
First round of updates:
I loved the look of the leather strap pulls for the window, door pull and catch release, but there are some problems. The leather has stretched abit, the window operation is a two handed job, but more alarmingly the door opens when the window is pulled up, and also when a passenger used it as a grab handle !! I thought I was being clever, by looping the window strap around the horizontal catch release to keep it from flapping around, but the pull-up action on the window ends up opening the door !!
I had found some great silicon/rubber strapping that I have been using in some jacket making (longer story). No stretch, matt black, and returns to its original shape.
The new design separates everything out, the catch release is a small loop just visible on the left. Whilst not as visually interesting as the leather (the window action is still a two handed job) it all works alot better...The bottom of the window strap is attached to the door frame to keep it in check and limit the window drop when opened.
http://i161.photobucket.com/albums/t...pspgyi4kjt.jpg
http://i161.photobucket.com/albums/t...psvstttyfw.jpg
http://i161.photobucket.com/albums/t...psjerp758j.jpg
http://i161.photobucket.com/albums/t...psrwllwc5g.jpg
Next up, rear torsion bars and anti-roll bar
Mutters....."it will never really be finished"
Chris
jury 12-04-2016 05:48 PM
Not exactly related to the car, but still important.
We got lucky finding a house (in the area we wanted to live) with a double Garage, but the drive is abit steep. I had been relying on some cut decking boards to make the transition from sidewalk to driveway. The boards work fine but I have to measure the placement every time I take the cars out, not a big deal but gets annoying, especially when the rain washes the chalk placement marks away.
So decided to make a semi-permanent solution. I drilled into the concrete and tapped in some lag shields, then screwed in some substantial lag screw hooks and sprayed in hi-vis fluro pink...
http://i161.photobucket.com/albums/t...ps1kwefubi.jpg
Next, took some drilled angle bar and attached to the existing Deck boards.
http://i161.photobucket.com/albums/t...pszwt1ye4x.jpg
The Deck boards now hook onto the screw hooks, which allows them to be placed in the same place everytime.
http://i161.photobucket.com/albums/t...ps0eymextq.jpg
Back the car down the driveway, hook the boards off and place behind the garden wall until returning home.
http://i161.photobucket.com/albums/t...psppabznv0.jpg
http://i161.photobucket.com/albums/t...psnqgq7dlz.jpg
http://i161.photobucket.com/albums/t...psytgpyyps.jpg
Next door has a nice four car garage (with four BMW M cars in there!!) but this will do for now :)
jury 12-04-2016 05:52 PM
I don't mind admitting my mistakes, this is one of them :(
As I was putting the miles on the car, I was 'pushing' it abit as well. I have my 912 to compare to, but the characteristics of the two cars are very different. The Modrod is very light...860kg light...and is set up firmer them the 912, though not uncomfortably firm. However I have been feeling the sensation of "Bambi on ice" from the rear...so did some rethinking. I know the rear roll bar is 18mm...hmmmm maybe this is too big. Next up Torsion bars. I thought I had ordered 24mm solid Sway-A-Bars for the rear and 20 for the front...but this was in 2008 when I had distractions like newborn twins and moving to the UK :rolleyes:
I found the order confirmation email from Pelican Parts (still had it!). Turns out the rear Torsion bars were 28mm !!! and the fronts were on back order and never arrived. So the car is set up with:
Front torsion bar - 18mm
Front roll bar -13mm
Rear torsion bar - 28mm
Rear roll bar - 18mm
As I said it is 860kg...No wonder it feels abit light at the rear :eek:
Since being back in Portland, I have met back up with David Hanning who sold me the '68 shell back in 2008. I discussed the torsion bar issue with David and he said he might have some 23mm rear torsion bars, he did ! and also had a 15mm roll bar !! Afew beers later they were mine and cleaned up...
...But the best part is, is that David has a new workshop complete with a car lift.
The workshop is only 10mins away, so off I went and got to work.
http://i161.photobucket.com/albums/t...pssnrn5mem.jpg
http://i161.photobucket.com/albums/t...psmu2iouvi.jpg
http://i161.photobucket.com/albums/t...pssizt70ze.jpg
Adjustable spring plates make torsion bar removal alot easier.
http://i161.photobucket.com/albums/t...pskynjkfhp.jpg
Its a whopper :eek:
http://i161.photobucket.com/albums/t...psrkmuob5a.jpg
23mm vs 28mm
http://i161.photobucket.com/albums/t...psk7ndm1el.jpg
Next, roll bar
http://i161.photobucket.com/albums/t...ps3n6bbhxh.jpg
15mm vs 18mm
http://i161.photobucket.com/albums/t...psiooet1gy.jpg
It was getting late, and this included a visit from the local plod...all good though. Set it back down and looks good.
http://i161.photobucket.com/albums/t...psaanezlax.jpg
http://i161.photobucket.com/albums/t...psn81ojvbz.jpg
http://i161.photobucket.com/albums/t...psk8oztnhl.jpg
And the result ? IT FEELS SOOOO MUCH BETTER !!
I only drove the short journey back home, but the feel from the rear is like night and day, it feels alot more sure footed. I will see how it settles over the next few days and tweak if needed.
It would be boring if you got it right first time ;)
