Question 1980 911SC O2 Adjustment ?
My 1980 911SC would run great but as soon as it warmed up it started to miss.
I had a stainless steel air box installed and it helped, then I found my catalitic converted was restricted so I removed the inside material which had melted.
Now it starts right up and runs great but after it warms up there is a slight power loss and miss..like it may be getting too much gas or not enough ??
Old 12-07-2008, 12:53 PM
mca mca is offline
mca's Avatar
Too rich? Does the idle hunt when warm?
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-07-2008, 12:57 PM
yes, the idle is inconsistent when warm
Old 12-07-2008, 01:00 PM
Designer King
Paulporsche's Avatar
As mca implied, a hunting idle or, if you rev from idle and the revs swing too low and then try to come back up to idle speed, the mixture is usually too rich.
Are you also getting a miss?
W/ a name such as ob juan, are you from a hot climate?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-07-2008, 01:03 PM
mca mca is offline
mca's Avatar
My initial guess would be that it is too rich. However, there are other factors that could also be at play such as your timing, vacuum leaks, etc.
If you don't have a gas analyzer or an air/fuel meter it may be in your best intested to take your car to a shop and have them test your mixture and check your timing.
If you want to give it a go yourself, get the car nice and warm. Then turn the mixture screw (using allen wrench or mixture adjustment tool) SLIGHTLY counter clockwise. Do this until your idle stops hunting.
Don't leave the mixture tool in place - turn a little and remove. Then give it some throttle, let the RPMS settle back down, then see if hunting idle is fixed. Repeat prodecure if idle doesn't stablize. Remember ... turn SLIGHTLY.
Before doing anything, wait for some more feedback.
Old 12-07-2008, 01:10 PM
Nice marmot.
mike_dunn's Avatar
I had a bad (original, made in W Germany) O2 sensor relay on my SC that caused the warm idle to hunt from 900-1100 rpms. Replaced it and the warm idle plummeted to 400 rpm on the next start up. Adjusted the mixture and control pressure. Everything was out of whack. Now the idle is steady, although I still can't find the sweet spot for my control pressure. Also, check for vacuum leaks.
Mike Dunn
Daytona Beach, FL
1982 PORSCHE 911SC
Old 12-07-2008, 08:21 PM
