How to re attack quarter window moulding?
How to re-attach quarter window moulding (old 911)? Tap it on to reciever groove in rubber window surround with soft mallet? Not sure how to do it. Doesn't seem to like mallet method. Bigger mallet?
Thanks EP Slick
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
abit off center
It has to go in before the window is put in.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
moulding
It is a 79 so the rubber goes in first.
Both the groove and rubber need to be s-l-i-c-k...
Use dish soap. Stay close to the ground (softer floor - the better) in case the window slips out. Spray soap on and keep it wet as you work the rubber into the groove.
pozee |
MAGA
I have a '79 and it is next to impossible to install the the metal trim into the rubber while the assembly is in the car. I did all mine when I did a headliner install.
Procedure: On a workbench, install glass into seal. Lube trim groove in rubber seal and work metal trim into groove (not always easy even when on workbench). Lube channel of rubber seal that engages body, install a string or wire (I use a scrap of 14 gauge plastic sheathed electric wire) into channel. Place assembly up into window opening and pull the string from the inside while a helper pushes on the outside and "rope" the assembly into car.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Porsche 911 SC, SAAB SPG
Jeff C |
