RS 73
HID Headlight kit ofr H4 bulbs
Does anyone have any experience installing one of those HID headlight kits for H4 bulbs?
There seems to be a version with HID low beam and Halogen high beam. Also another type that refocuses for high beam. I am contemplating installing one of the re-focusing ones which seem to be solenoid operated. Any experience or input on this from this board? Thanks. Dick
Dick Lague RGruppe #79 1973 RS Spec Carrera 2001 Saab 95 Aero 2003 Saab 95 Aero Last edited by dlague; 11-12-2008 at 10:06 PM.. Reason: typo |
Member 911 Anonymous
Do you have a pic or link of that refocusing unit?
Keep us posted, like to see it in action
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RS 73
I am surprised that no one has messed with these kits. I will try to find a photo of the one I am considering.
ANYONE!!
Dick Lague RGruppe #79 1973 RS Spec Carrera 2001 Saab 95 Aero 2003 Saab 95 Aero |
I am actually purchasing a kit myself. I really dont use my high beams so I am going with a 9003 kit. ( same bulb but single element) I will post pics when i am finished!
I would venture over to the BMW world for HID stuf... my son has a new to him used 99 M3 with HIDs and we went through a nut-roll on geting correct bulbs...
try bimmer forums > they have a whole string wrt HID
Kim Langley 2012 Carrera / 991.1 80 911SC 97 C230 73 BMW 2002Tii |
I have an HID kit in my Ruf BTR and it has high and low beams, I bought the kit from Imagine Auto in Lenexa, Kansas but I think I prefer 80/100 watt H4 bulbs. The HID provide better quality light but I like the distance I get from the 80/100 bulbs on back roads and dark highways with the huge deer population here in Michigan.
RS 73
Here is the link to the site that gives you and idea of what the H4 kit is like.
http://www.v-leds.com/Shop/Control/Product/fp/vpid/4782976/vpcsid/0/SFV/32481# I hope Wayne does not mind......he does not sell HID to my knowledge. I have bought LED taillights from this company and they see to be reliable.
So you meant the normal 80/100 bulbs give you further distant compare to the real HID?
Fat butt 911, 1987 |
HID's are usually coupled with projector style lenses. How do they look when diffused with our old skool lenses? Got to love the "warm up" when the bulbs flash on and change color.
Go Speedracer, go!
I put an HID kit on an older Audi that I used to have with the fluted style lens similar to an h4. It was terrible. I switched back to the plain old halogen bulbs not long after. The problem is that the arc of the HID bulb is a different shape and length of a halogen filament and it causes the beam pattern to be wacky. It produced a U shaped beam that blinded oncoming traffic, and it was very unfocused, or muddy. In my opinion it was dangerous for oncoming traffic. You really need a projector style lens to work correctly with an HID bulb.
I have 80/100w bulbs in my 911, and they put out as much or more light than the factory HID projectors on my S4.
1981 SC ROW Coupe |
Porscheaholic
I have one of the HID kits they were plug and play and work great ! I bought them off the bay
I'll Keep My Guns, Freedom, & Money... You Can Keep The "Change!" 1994 c4 widebody current 1995 993 gone 1977 911s Widebody 3.0l gone |
Can you post a pic?
did you replace lenses or keep the original lenses? Do you have pics or the patern?
Thanks.
Porscheaholic
![]() ![]() This pic is of the High Beam ![]() This is the regular beam, it is actually brighter than the high beam because the high beam is not an HID beam. The only time I use the High beam is to flash someone to move over or if there are cops near by. ![]() ![]() ![]() I bought them on eBay but they came from Vertex Auto. They were $139 with my best offer. IMO it may be the best money spent on an upgrade. Matt
Porscheaholic
http://www.**********.com/ShowItem/197848%20Porsche%20H4%20Xenon%20Light%20Kit%206k%2 0-%20White%20In%20Color.aspx
Here they are. If you call them I'm sure they will knock the price down
Porscheaholic
You replace all the old bulbs and must mount the ballist inside your hood. I had to drill a 3/4 inch hole for the wires to fit. We did a 965 at the same time and did not have to drill any holes. Mine is 6000k and his is 8000k
I installed a HID conversion recently into my 81 SC and the results are fantastic. I have far greater vision now. It was a bit of work as the kit was obviously designed for a conventional head lamp set up ie lamps in the engine bay.As the 911 has lamps out on the fenders the factory wiring had to be replaced with the special looms for the HID, washer bottlr, horns removed for access a bit of hole enlarging. My driving lights in the valance panel are now invisible as the HID seems to light right in front of the car out to the side and way down the road. I have had no flashing from on coming vehicles so they are not dazzling them. A good result.The ballast units look very similar to those pictured high beam and low beam are great. I used standard Porsche H4 lenses etc although new ones.
Germany has some weird driving laws, and not using your fog lights unless you're actually in a low visibility situation is one of them. In one way it makes sense.
'84 911, some sort of red color '05 Subaru WRX wagon |
Go Speedracer, go!
Here's a good article about converting your halogen fixtures to HID.
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html This is one reason why I switched back.
1981 SC ROW Coupe |
| Tags |
| headlights , hid , installation |
