Update Ignition System
I posted a thread on twin plug or not and after much research I am not sure if it is the best thing to do or not.
Is there a plug / coil / ignition upgrade I could do that would get me almost as good as twin plugging? 2.7 RS 10.5 compression, very wild cams Thanks |
back off the timing and run better fuel.
I will do that for sure but should I upgrade from the stock coil?
It couldn't hurt, but it is certainly no substitute for twin plugging.
Edit: Steve Weiner at Rennsport Systems has a good explanation here (article #6). |
The ONLY downside to twin-ignition on a 911 is the expense,.....:) There are many benefits that include improved torque, quicker throttle response, cleaner running, and improved resistance to detonation. The latter item becomes much more critical when compression ratios exceed 9.7:1 on pump gasolines. Without knowing all the details of your engine including what octane fuel you plan on using, I couldn't offer anything more specific,...:) |
I am starting to think twin plugging is the best thing to do. Thanks for the advice.
| All times are GMT -8. The time now is 08:17 PM. |
