Bits in the transmission
I changed fluid today and found these bits in the transmisison.
1. Is it gears or synchros?
2. How many more miles will it last before it shifts no more?
I like to drive it a little more before rebuilding it. Too many projects this year.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-13-2008, 04:19 PM
Oh Haha's Avatar
Dogteeth. I would advise against driving it any more until you rebuild it. You'll need to open it up to see which gears are destroyed.
Pacific Blue
Wayne
Old 12-13-2008, 04:25 PM
So, what damage will it do if I drive it more. I mean, the damage is already done...
Old 12-13-2008, 04:45 PM
1st dog teeth from the angle of the teeth. there are a few more holding the syncro in place. the rest of them can break at any time and the syncro will expand and you won't be able to engage 1st. then the syncro and brake band may be caught in the works, twisted into a pretzel and broken into chunks, often taking gear teeth with them in the process. so no, don't drive it.
206 637 4071
Old 12-13-2008, 05:48 PM
OK John, if I do this myself (just the gears that need replacing), how much will it cost? And if I send it to you, how much will it cost for a rebuild that you will feel good about?
Old 12-13-2008, 05:53 PM
you can do 1st and 2nd by dropping the engine and trans as a unit and removing the end cover and intermediate housing to expose the gears. then remove the two roller bearings, remove 1st gear from the pinion shaft, remove the 1st/2nd shift fork bolt, after measuring exactly where it sits on the shaft, tap off the fork and the shift sleeve and slide off 2nd. this can all be done with the trans still bolted to the engine if you don't think the clutch needs to be looked at. a full, average/normal rebuild, trans only, can average $2K easy these days. that's trans only, no R&R.
206 637 4071
Old 12-13-2008, 06:59 PM
The thing is already on the floor of my garage. I was doing a clutch job and changed the oil at the same time and that is when I found all the bits. I guess this will be my winter project.
Old 12-13-2008, 07:53 PM
TibetanT's Avatar
Will you be posting pictures and details of this project?
I think it would benefit many here, including myself, to be able to follow the progress.
I hope so and good luck!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 12-13-2008, 08:08 PM
Bart_dood's Avatar
Any idea how it happened? might help others avoid this issue.
1997 Boxster SOLD
1999 R1100S SOLD
1988 Carrera 3.2
Old 12-14-2008, 08:41 AM
