"Grüne Hölle."
1967 & 1968 interior rear trim -- what's correct?
We have a 1968 Porsche 911 coupe, which seems a changeover year with some unique characteristics.
I've seen two types of the cap panels that go over the rear side panels (under the quarter windows). One is essentially a straight cap, and the other type has a "C" shaped end on side towards the B pillar. This type actually wraps around the B pillar with one extra screw to fasten it into the B pillar. Which is correct? I have one of the "wrap around" style right now in my car on the driver's side and one of the simpler straighter style on the passenger side. I actually like the wrap-around one around better style-wise and, since our car is a bit of a hot rod, I'd ideally like to find a matching wrap-around top/cap for the passenger side. But what year & model Porsche did these come from??? Thanks in advance for your comments and sharing your knowledge.. that's what makes this Board so helpful. Best Regards, Andy Here's the wrap around style: ![]() And here's the straight style:
1968 Porsche 911 "hot rod" Aetna Blue #118 35153 1986 Porsche 951 SteinGrau All Original "Pro Patria Vigilans" |
I'm almost 100% sure the 68 had the straight ones the wrap around came in 69...cause 69-on had the the trim panel that ran down the edge of the door. On the 65-68 the rear panel the vinyl material wraped around and was held in by the door seal...
Tony Proasi 1969S 1957 VW Pickup |
+1. 911quest is correct
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Nobody
I have the wrap around style.
I have the wrap around on my '68 SWT.
John Thompson Eugene, Oregon |
No sir..
"Grüne Hölle."
The wrap-around one I have on my driver's side rear area is simply vinyl glued directly to the metal basis. This would argue for it being from 1967 or earlier, wouldn't it? I mean, I thought the 1968 door caps were the first time they were padded -- new federal safety regulations came out in 1968, right?
The straight one I have on the passenger side rear area is padded slightly. So maybe correct 1968 model... So I guess I'm looking for a wrap-around from 1967 to match my existing one??? ![]() Or, if the 1969 wrap-around ones are identical but with padding, maybe I could find one of those and remove the padding to match.... It's an idea, anyway. Andy
The difference might be early '68 cars and or 911L's verses regular 911's. The '68 911S was a ROW car only. My early '68 912 has the non-rap-around and non padded door and rear pop-out covers.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
Guys,
I think this may be an issue with USA spec vs. RoW and manufacture date before/after 1/1/68, not model year. I have both a virgin ’67 and a virgin USA ’68 manufactured after 1/1/68 here. After it warms up a bit and I venture out, I’ll report. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
I stand corrected....maybe it is a mid 68 difference the 68 I jut parted didn't have the wrap around trim.
(Can't trust those mid-year changes...)
Andy was asking me questions on eBay about some of my parts.
I have a few cars here so I took a couple pictures. I have not seen a 68 912 as of yet with a wrap around rear bolster. I have not seen many 68 911 cars. 68s are funny though. The first ones used 67 engine grilles - then the 68-69 one, door panels are hard to reproduce, same with dash and bolsters, lots of mixing of parts on the 68 transition year. Pictures: 67 911 soft window targa 68 912 early car 70 911 72 911 73 911 ![]() ![]() ![]() ![]()
VintageExcellence.com Last edited by confused; 12-16-2008 at 10:16 AM.. Reason: refinement |
