Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Is there a downside to cutting off front tie downs?
I am in the process of installing Elephant PB bushings on the front. Looks like the PO had a few run ins with the front tie down brackets (the ones on torsion bar covers) and bent them somewhat. My thought was to to cut the tie downs off as another impact could potentially twist the all important covers which just happens to hold the front suspension in place. Good or bad idea?
Old 01-25-2009, 04:01 PM
avt007's Avatar
I find they serve a good purpose as the firs thing to bottom out in a bad bump.
Rob
76 widebody project
86 Carrera Coupe
01 BMW X5
98 Jaguar XJ8
Old 01-25-2009, 04:05 PM
Banned
Mine were ground down pretty good. I had a tow truck driver try to hook to them. Apparently he didn't hear me tell him not to use them.
Car got about halfway up the flatbed and one broke. Ripped my front valence almost completely off.
There is a lot of tension on those cables and hooks.
AAA sponsored tow company, so AAA body shop repaired all the damage no charge.
Long story short, If you are not using them for bottoming out protection, I would remove them. They can only cause problems if not in good shape.
The bottom out protection is good. Maybe cut the loop so no one can try to use them to tow if they are weak.
Old 01-25-2009, 04:38 PM
gungadin's Avatar
tie downs?
'76 911S w/ '79 3.0 SC engine. Irish Green
Old 01-25-2009, 05:10 PM
if they are starting to grind down then they are definitaly serving the purpose of protecting from bottoming out.....no matter what i would never have a tow truck use them....ive seen perfect ones break at the welds!!!
Old 01-25-2009, 09:20 PM
SteveinTO's Avatar
Very handy exiting steeply angled driveway. Makes horrible noise. Doesn't hurt car.
Old 01-25-2009, 09:53 PM
moneymanager's Avatar
These can be used as tie downs but they are there to keep you from bottoming out the front torsion bar mounts on a big dip or driveway taken at intemperate speed. I would guess removing them will one day cause you some extra front suspension work.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 01-26-2009, 07:40 AM
Zeke's Avatar
I'm not so sure. The shock from banging them is gonna be the same as if you hit the real protector, which is what the tie downs are connected to. The bushing holder is underneath all this.
At the very least, I'd bend them over at a 45* with heat. Please remove them to do this.
Old 01-26-2009, 08:29 AM
I think the tie down loops are designed to give, but if hit hard enough it won't make a difference. I replaced mine with the Rennline tow hooks and I'm switching back. The Rennline pieces are made for towing, and hence very stiff, which resulted in some damage to my suspension pan when I recently contacted a metal plate in the road. If I'd had the stock pieces in place, the damage would not have been more than a good scrape and possibly damage to my rubber spoiler lip.
Old 01-26-2009, 09:54 AM
AutoBahned
RWebb's Avatar
Originally Posted by gungadin View Post
tie downs?
- somebody post a pic of these so we'll all know, eh
Old 01-26-2009, 10:46 AM
Performance, Tweeks, Automotion or ? used to sell curvy steel skid plates that sandwich around the existing tie down bracket. They provide more sacrificial material as the front end skids off steepish driveways. They also add about a pound to the front end, down low and forward where it does the most good .
JMPro adapted roller blade/skate board wheels on a bracket that allowed the front end to roll over the interfering ground surface (or road kill). However, the suspension travel on these is the same as the factory bracket, and they seem to work best going straight (zero slip angle) unless he also had a caster wheel option.
Sherwood
Old 01-26-2009, 11:50 AM
Mine came with reinforcements tacked on. The previous PO never used them but my driveway is not as nice especially on a full tank
Old 01-26-2009, 11:56 AM
rfloz's Avatar
Just lower the car - they will grind themselves down in fairly short order.
Bob F.
1984 Carrera Factory Turbo-Look
Old 01-26-2009, 12:50 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
Sherwood
wonder if i can find the thread with the angle iron and the caster wheels
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 01-26-2009, 01:18 PM
OldTee's Avatar
My solution. Has come in handy when I needed a flat bed tow.
Old Tee
all 911s sold
Old 01-26-2009, 01:29 PM
Been on my car for about 5 years now and still going strong
JMPRO
Old 01-26-2009, 02:51 PM
mine were almost ground through so i added weld to make them round again. Theyve saved my chin more that a few times
Old 01-26-2009, 03:14 PM
