HElp with body/paint job
Hello,
I instaled steel turbo flares on my 911 and now I am preparing for painting. My question is: does the black primer/paint that comes on the new steel flares has to be removed or I can spray the primer ovr it after some sanding? Thanks a lot
Mario '76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger '15 GT3 |
Make sure it's clean of any oil or wax, then scuff it and prime it. No need to take it off. Don't sand before cleaning. It drives the contamination into the base coat. Sand nicks and scratches to bare metal.
that black primer is an E-coat and you should just scuff it if possible with scotch brite before priming with buildable/sandable then go from there
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
OK, smarty
, tell him what an E coat is.....
Max Sluiter
E-coating is like powder coating, only it can be done with liquid. The metal part is negatively charged, the coating paint is positively charged. Opposite charges attract and give a very thorough coating with less waste.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
thanks a lot
