Injectors won't come out on my SC
I have the intake tubes out of my '79 SC but I cannot get the injectors out. I hear that they should just come out, but even with significant force I cannot push them out. Any suggestions?
Old 12-16-2008, 12:01 PM
grateful user
don gilbert's Avatar
soak them in pentrating oil, then put 2 large screw drivers on both side and pry them out.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 12-16-2008, 12:09 PM
Nice marmot.
mike_dunn's Avatar
I just put my foot on the intake and use vice grips to yank them out. If you're reusing the injectors, try not to damage the threads with this method.
Mike Dunn
Daytona Beach, FL
1982 PORSCHE 911SC
Old 12-16-2008, 01:27 PM
oneblueyedog's Avatar
I hope I can explain this correctly.
Get a 10mm (I think) open end wrench. Put it between the injector body and the fitting nut.
Get a screwdriver and put it under the wrench wedging it between the wrench and the intake runner.
Push down on the free end of the wrench against the screwdriver that's against the intake runner. It acts as a lever/fulcrum.
The o-ring will either stay in the runner or stay on the injector.
It takes some force to remove them. Use some silicone grease to lube the new o-ring on reinstall.
If the cis is off the engine, it's a great time to replace the phenolic sleeves and o-rings. See the threads on this.
Hope this helps. Cheers
78SC coupe, Silver Metallic
Old 12-16-2008, 02:05 PM
mca mca is offline
mca's Avatar
I think there is a tool that will thread onto the injector which will allow you to pull them out. I saw it in the Bentley and would love to know where to get one.
I pounded on mine with a rubber mallet (from the spray side of the injector) and then had them cleaned and bench tested.
You will likely need to replace the sleeves, sleeve o-rings and injector o-rings. Parts are cheap and is worth doing with the CIS off of the engine. Same goes for the boots.
EDIT: The sleeves may be staked too so you may need to grind them off. I didn't restake mine b/c they seem to hold without being staked.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 12-16-2008, 02:25 PM
MBAtarga's Avatar
This is a picture I saved from a thread on this subject. It was posted by Jim Williams, but I don't have the thread number - the title was CIS Injectors.
Mark
'83 SC Targa - since 5/5/2001
Old 12-16-2008, 05:08 PM
