-   -   Cat bypass hardware (http://forums.pelicanparts.com/porsche-911-technical-forum/447504-cat-bypass-hardware.html)
CT944 12-21-2008 01:19 PM
Cat bypass hardware
Does anyone know what gaskets and nuts/bolts I need to install a cat bypass?
Nine9six 12-21-2008 02:31 PM
Try doing a search on "cat bypass"...The same question was recently posted and answered.
SteveinTO 12-21-2008 10:28 PM
There's a picture in the Pelican catalog, I think three gaskets involved. Pretty simple. Be prepped for a trip to the hardware store for replacement metric nuts & bolts as you will probably have to dremel several of them into submission.
Gogar 12-21-2008 11:23 PM
You need 3 gaskets, the first three on this page here:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_EXHpip_pg6.htm
and 9bolts, (+nuts and a lock washer) M10 x (at least 32). you might need to adjust the length of the bolts a little bit depending on the thickness of the flange on your bypass pipe.
Have fun!
spence88mph 12-22-2008 12:35 AM
m10? m8 isn't it??
m110 12-22-2008 10:18 AM
Search "will ferch" and cat fasteners
Gogar 12-22-2008 10:31 AM
Or, type in
catalytic converter gasket
into the search window. Cryptic, I know. :)
CT944 12-22-2008 02:23 PM
Have fun!
Thanks Gogar!
